Author Topic: Kubota L 4200 clutch replacement  (Read 4681 times)
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« on: November 13, 2014, 04:19:01 PM »
We, [Wild Bill mostly] will be replacing the clutch in the Tractor in 2 weeks. Any suggestions, thoughts, advice?
L4200 4wd GST with FEL.
The First 60 years of childhood is always the hardest.
Offline beenthere
Re: Kubota L 4200 clutch replacement
« Reply #1 on: November 13, 2014, 05:05:53 PM »
Bill
I didn't think one used the clutch in a GST tranny tractor. What happened for the clutch to go out?
Do you have the shop manual for the L4200?
Here are a couple links to some posts that may help, one includes a cross-section of the clutch.
Kubota L4200 - first
Kubota L4200 - second with clutch pic
Offline Raider Bill
« Reply #2 on: November 14, 2014, 07:37:48 AM »
We all use the clutch, never got used to not pushing it in when shifting or changing directions.
I bought the tractor used and have treated it pretty much like a dozer. I think most of the issue started when I was clearing woods with the bush hog. I figured if I could push a tree over then I could munch it up with the  bush hog. Too many times I stalled the tractor out that way. ( I now have a slip clutch installed)
Just lost it's get up and go power. We've been adjusting the clutch pretty regular but it looks like we ran out of threads.
One thing of concern is a couple years ago when I was changing out the hydraulic filter I found cellophane stuck down into the old filter like someone put one on without taking the protection film off the new filter. Hopefully this didn't work it's way into a valve body or something.
Offline Reddog
  • Forest & Urban woody plant management
« Reply #3 on: November 16, 2014, 10:50:59 PM »
Got a service manual?
Most need to be split at the bell housing/steering wheel and pulled apart to get to the clutch pack.
Cribbing for support after you split it.
Most tractors you need to remove all the FEL brackets to split them.
Offline Raider Bill
« Reply #4 on: November 17, 2014, 09:44:47 AM »
We made a set of brackets to hold the FEL when we take it off and started dribbling Blue Creeper on fittings and threads.
The plan is to block the front then roll the back away to expose the clutch. DanG suggested to keep the brush hog attached and the PTO engaged for a counter weight and so we can turn the shaft for lining up the splines.
Offline Mapleman
« Reply #5 on: November 17, 2014, 10:13:36 AM »
When blocking up the front end, don't forget to put blocks or wedges between the frame and engine so the engine assembly can't rotate around the front axle pivot point.
"The older I get, the better I used to be."
Offline Reddog
« Reply #6 on: November 17, 2014, 10:55:57 AM »
Sounds interesting, take pictures.
Offline wildbill
  • looking around
« Reply #7 on: November 17, 2014, 11:57:29 AM »
Keep pecking away at it before I get there and you might finish.  Wouldn't hurt my feeling none if were done before Saturday :)
Raider Bill's favorite son
Offline wildbill
  • looking around
« Reply #8 on: November 23, 2014, 08:19:49 PM »
Offline customsawyer
    • The Custom Sawyer
« Reply #9 on: November 23, 2014, 08:21:26 PM »
That's a start.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline wildbill
  • looking around
« Reply #10 on: November 23, 2014, 08:23:05 PM »
I'm on vacation, taking it easy :)
Offline r.man
« Reply #11 on: November 23, 2014, 08:31:13 PM »
I tried to help an older friend and one other fellow roll the back end of a Cockshutt 30 forward to bolt up to the front half after some clutch work. On dirt and a bit irregular so I suggested two cable winches, one for each side. He was able to join the two halves by himself in a leisurely controlled fashion.
Offline sandhills
« Reply #12 on: November 24, 2014, 12:27:44 AM »
Quote from r.man, "He was able to join the two halves by himself in a leisurely controlled fashion" just be patient, and line things up right.
Offline Raider Bill
« Reply #13 on: November 25, 2014, 10:29:41 AM »
Getting the front drive shaft to line up is hampering us now. It runs inside the case on the bottom and has a sleeve so we can't get on to turn and line up the teeth. We are able to turn the main shaft via either the PTO or crank but that won't spin the bottom/front shaft.
Clutch spring replacement
Started by CWS on Chainsaws
Last post February 02, 2004, 07:32:32 PM
by CWS
Husqvarna 350 Clutch Replacement
Started by AndyC on Chainsaws
Last post July 19, 2009, 06:52:01 PM
by rebocardo
Stihl MS310 clutch replacement
Started by 3584ELK on Chainsaws
Last post April 01, 2017, 03:03:53 PM
by 3584ELK
Deere 440a clutch replacement
Started by thenorthman on Forestry and Logging
Last post June 13, 2016, 11:16:32 PM
by ohiowoodchuck
