Author Topic: Tempering an axe head  (Read 3488 times)
Offline shinnlinger
« on: November 23, 2014, 09:31:16 AM »
The Internet is fairly divided on how to remove the busted handle out of an axe head.   Some  say burn it out others say never.
Now that we are making handles
In the shop inevitably a burnt head will come in.   What is an easy way to test for temper?
Does it really matter?   It's not like they are ever going to be used for much more than busting up kindling.
That said, I have a torch and can draw colors and can quench in oil and bake in the oven and all that.
Anyone have any good pointers?
Shinnlinger
Offline Reddog
  • Forest & Urban woody plant management
Re: Tempering an axe head
« Reply #1 on: November 23, 2014, 12:02:38 PM »
Pretty good write up on cold chisels and temps.  http://www.appropedia.org/Hardening_and_tempering
What I would try. And by try you know that all heads are going to be different materials. So if it comes out to soft you would need to adjust temps.
Using a carbonizing flame heat a 1" to 1 1/2" strip at the cutting edge to cherry red or slightly above, oil quench and agitate to below smoke point. Finish by air cooling then check for hardness.
If hard proceed to draw, if soft reheat and quench using a higher/hotter color
Use a furnace to draw temper at 500DegF for 6-8 hours.
And as always YMMV   ;)
Offline JB Griffin
« Reply #2 on: November 23, 2014, 07:58:14 PM »
X2 except for I would use transmission fluid, heated to approx. 95-125 deg and heat the head till non-magnetic, draw in oven at 425-600 deg for 2hrs, 1 hr then let cool to room temp then another hr, but atleast 1 hr. Hope this helps
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline gspren
« Reply #3 on: November 23, 2014, 08:07:09 PM »
  First try to sharpen with a file and you should be able to tell if it's hard, if it files like a chainsaw chain your good, if really soft try as suggested. Just remember if it's a cheap mild steel head it won't get hard, just not enough carbon in it.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #4 on: November 23, 2014, 08:10:05 PM »
I think you can if You dip the hot end into high sulfur oil
A&P saw Mill LLC.
License NH softwood grader.
Offline JB Griffin
« Reply #5 on: November 23, 2014, 08:12:24 PM »
If it files like a chainsaw chain it's too soft. The file should cut it but not very aggressively but it should cut it.
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
« Reply #6 on: November 24, 2014, 07:48:49 AM »
Some of my old logging books mention how to burn out a handle out of an axehead so you dont loose the temper. You take the axehead and stick it blade down into damp earth a couple inches then you build a small fire around it. The damp earth will keep the blade from loosing its temper.
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Offline gspren
« Reply #7 on: November 24, 2014, 06:55:12 PM »
  Steel needs carbon to harden, you can case harden by repeatedly heating and dipping in powdered carbon such as Casenit before quenching but that's a bit more involved and it won't be deep.
Offline loggah
« Reply #8 on: November 24, 2014, 07:07:13 PM »
I've made really good cold chisels and punches from Re-bar before,its cheap steel and high in carbon content.
Offline 36 coupe
« Reply #9 on: November 26, 2014, 05:31:46 PM »
Do not burn out the handle stub...An axe has a high carbon steel edge forge welded to a softer head.As usual a simple looking tool has many steps to making it.Forget case hardening..The handle stub can be drilled out.The remaining wood can be driven out with a punch.
Offline PineNut
« Reply #10 on: November 26, 2014, 09:41:44 PM »
Drilling out the old stub is my way also. Also quicker than burning it out,
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #11 on: November 26, 2014, 09:48:44 PM »
 I also drill and punch out, no burning of axe head for me .
   Marcel
Offline Billbob
  • Retired..I need to find a job so I can get a rest!
« Reply #12 on: November 27, 2014, 06:44:31 AM »
Drill and punch out is my preferred way as well.
Woodland Hm126 sawmill, LS 72hp tractor with FEL, homemade log winch, 8ft pulp trailer, Husqvarna 50, Husqvarna 353, homemade wood splitter, 12ft dump trailer, Polaris Sportsman 500 with ATV dump trailer
Offline 36 coupe
« Reply #13 on: November 30, 2014, 12:46:03 PM »
Drill and punch out are the only safe way.Forums are full of it AS in BS ,beware of BUM INFO..
Offline drobertson
« Reply #14 on: November 30, 2014, 02:17:55 PM »
I've seen a few old cutting tools that have suffered in barn fires.  I don't have the double bit now, either the tornado got it, or someone stole it,  it was Grandpa's, He had me as a kid help him clean them through our summer trips, All I remember Grandpa saying when we had them cleaned up is " wish the barn had faired as well"  They sharpened up like new,  I guess , I've heat treated a pile,  seen lots of  strange things, so it seems that a fire burning out for the short period of time it probably would take,  the likely hood of a red heat would be slim, if it did it just seems it would burn out before the transfer to the bit edge.  I don't know, just saying.  I would drill and punch out, well I have in fact, several times,  I sure miss Grandpa, and that ole axe,,
Cryogenic Tempering
Started by Bendavid on Sawmills and Milling
Last post January 11, 2007, 04:02:34 PM
by Gilman
Flame Tempering of wood
Started by Spruce_Goose on Drying and Processing
Last post September 07, 2013, 01:13:04 PM
by GeneWengert-WoodDoc
tempering cast iron woodstove
Started by Cord-n-8R on Firewood and Wood Heating
Last post February 18, 2009, 07:06:50 PM
by tyb525
Turning Block Storage - A Tempering Room
Started by Lud on General Woodworking
Last post January 15, 2010, 05:20:38 PM
by Lud
