Turning buzz saw blade into ripping blade.
Started by Joe Hillmann, February 06, 2017, 11:53:10 AM
Joe Hillmann
I am thinking of building a swingmill but don't really want to spend $500-$1000 on a blade that will cut ten inches.
I can find all sorts of old buzzsaw blades  from 18 inches up to 3 feet for $20-$30 a piece.  Would it be possible to convert on of them into a ripping blade?
I know I would have to drill and countersink holes to mount it since a swing mill blade can't be mounted with a simple arbor and nut.
I was thinking of removing every other tooth and reshaping the ones that I leave into ripping teeth rather than crosscut teeth.
Is there any reason this wouldn't work?
Kbeitz
Buzzsaw blades have zero or neg rake. You might need to resharpen
them to a different geg.
Love machine shop work
and Wood work shop work
And now a saw mill work
Joe Hillmann
Quote from: Kbeitz on February 06, 2017, 07:36:00 PM
I have one sitting here and it looks like it has about 8 degrees negative hook and every other tooth has an alternate face and tip angle.  I would reshape the teeth so they have a 10 -15 degree angle with a flat top and flatter face,  I may still keep some of the alternate face angle though.
I had also thought of knocking of three teeth, leave one, knock off another three, leave on and so on but I think that would require cutting a deeper gullet on the remaining teeth.  So now I am thinking it may be better to remove every other tooth (which would require changing the set on every other tooth a lot and could cause them to break off)or leave them all causing each tooth to take a smaller bite.
Joe, its doable, you will need to put some hook on the teeth. If you draw a chalk line from the arbor hole to the rim and measure half way. Run a straight edge from that mark up to a tooth face that should match it. As Kbeitz said cordwood saws have zero rake that is tooth face will follow a straight edge to the arbor center or negative rake which is less. How efficient the saw will be I don't know it may pull hard. Myself I think I would buy a saw with bits and shanks like a head saw or a commercial edger saw. Frank C.
Really Joe, a circular saw running at speed is not something to cut corners with, or its mounting, you will be so close to it. Frank C.
Ljohnsaw
Quote from: bandmiller2 on February 06, 2017, 08:11:16 PM
And I'd be concerned about getting it balanced after all that cutting and grinding...
John Sawicky
Darrel
I tried making a rip blade out on a 10" negative rake blade once about 40 years ago and I came to the conclusion that it was a whole lot more work than working to earn the money to buy the blade I really wanted. I did learn a bunch and I proved that it could be done. As I recall, I ended up taking all the teeth off and starting over with about a third of the teeth of the original blade.
1992 LT40HD
Kbeitz
You might want to look for a good blade on E-bay.
This is where I got my blades for my swing chop saw.
I got 16" new in the box blades for only $20.00 each
and I'm very happy with them.
TKehl
How big of a cut are you wanting to make?  Used 40-42" circle blades from say a Bel-saw are out there fairly cheap.  Not as common as buzz saw blades, but nowhere close to rare.
In the long run, you make your own luck – good, bad, or indifferent. Loretta Lynn
Joe Hillmann
Quote from: TKehl on February 07, 2017, 07:13:52 AM
That's way bigger than I am looking for.  I am thinking 20"-24" for the blade.
TKehl
New 24" blade for Lucas model 10; $240 + shipping.
P/N:  DT10 18
Joe Hillmann
Quote from: TKehl on February 07, 2017, 06:39:24 PM
P/N:  DT10 18
That is much more reasonable than the ones I had found.  I'm not sure what brand I was looking at but a 20 inch blade was around $500 and the same size blade with inserted teeth was around $1000
Kbeitz
On E-bay now...
20" Buzz Circular Mill Saw Blade 100 Teeth 1" Arbor  $44.99
Large Saw Blade 20" 40 Tooth 6 Hole Bolt Pattern Carbide Tipped  $40.00
20" Buzz Circular Wood Mill Saw Blade 54 Tooth 1" Arbor $44.99
Joe Hillmann
Quote from: Kbeitz on February 07, 2017, 07:03:39 PM
On E-bay now...
Can you pm me a link to the middle one?  I can find the other two but that one I can't and that looks like it may be closest to what I am looking for.
