Top rail covers
Started by ncsawyer, May 16, 2015, 05:30:33 PM
ncsawyer
I keep my mill under a cover when not in use until my mill shed is finished.  To keep moisture off the top rail and make sure I don't run into any rust issues, I made some covers out of 1.5 in PVC.  I laid them on the table saw and ripped the side off of each pipe.  The opening on the bottom of each cover is just big enough to snap in place over the rail.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
Delawhere Jack
That has been on my "to do" list longer than I care to mention...
Percy
That is a great idea!!!
kellysguy
I wonder if they will trap moister underneath?
Nomad
     I use foam pipe insulation from the big box store.  Cheap, easy, can toss it behind the seat in the truck for transport, and readily available.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
fishfighter
If you are getting rust build up on your tracks, y'all not sawing enough. 8)
DR Buck
In 11 years I've never covered the rails.   Never had a problem with them.   Seems like overkill and just another thing to remember to take off, or put on.
