Remodeled sharpening room
Started by redbeard, February 21, 2018, 02:32:23 PM
redbeard
  we have been working in the wood shop alot this winter organizing and decided to re do the  sharpening room, mainly because i was unable too sharpen the 23' Hud-son 60 blades easily.
Also enclosed under the sharpener with some clear freezer curtians that fork lifts go through. Handy stuff for alot of projects.
Added a pan that catches grindings that slides in n out.
Made what I call towers that are different heights for blade widths with teflon tops with bearings.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
paul case
pc
Very Nice Indeed.  I hope that you do not put much weight on those table tops and crash them in. :o  :D
Darrel
1992 LT40HD
SawyerTed
That's a good looking arrangement.  I like the table tops!
terrifictimbersllc
JB Griffin
Good idea on the blade supports. And nice setter you got there.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
