LT-15 Trailer kit
Started by John S, September 07, 2008, 12:27:22 PM
John S
WM no longer offers a trailer kit and their load assist kit is not designed to work on the landscape trailer that I have.  Does anyone out there have a kit that they are looking to sell or know of any plans to build a similar kit for the LT-15?
John
2018 LT40HDG38 Wide
Meadows Miller
Gday John
I had a little Jonsered 6000+ that I use to shift around with a 6'x10' tandem car trailer roll the head to the far end of the mill lift the empty up slide some blocks of wood under half way along the track back the trailer under push the head back to the start and push the mill into the trailer to unload roll the head out over the end of the trailer and pull the traler away To EASY I was able to do that on My own even tho Id welded 2  extra 4x2 20's to the bottom of the track/mill frame to stiffen it
Good Luck
Reguards Chris
4TH Generation Timbergetter
Bibbyman
I don't have a trailer kit or an LT15 but for those who owners that may not know about the new trailer loading kit, here is a link to the Wood-Mizer website showing how it works.
Wood-Mizer LT15 load assist kit
Sawing since '94
