Felling wedge pouch and hammer?
Started by Dieseltwitch, June 22, 2016, 10:20:36 PM
Dieseltwitch
Im looking for a good pouch to carry felling wedges. All the ones i can find carry one of each size. I really need one small wedge, two mid sized wedges and one long wedge. Any one know of one that would work for this?
Also what hammers are people using. I tried using a sledge but its not balanced very well and when its in a hammer ring it tries to flip over and fall out.
Ljohnsaw
Would a carpenter's nail pouch be too big?  Perhaps find one that is just about right and go to a shoe repair or a saddle maker and have them do some extra sewing on the leather to customize it.  For a hammer, how about a carpenter's claw hammer.  Has straighter claw and a long handle.  Usually 20 oz so should be adequate.
John Sawicky
RHP Logging
I modified a carpenters pouch.  And the hammer I'm using is a 4 lb axe.  When you've got a hard back leaner good luck with anything less.
Buckin in the woods
Plankton
Go to a carpenter supply place and look through the different tool pouches/belts. They make all sorts of different sizes and shapes. When I did framing a lot of the guys wore those full harness belts with shoulder straps there was a pouch on them for a drill I think that I always thought would be perfect for wedges.
I reccomended skipping the hammer and using an axe. Some backleaners are hard drivers even with a 4 lb axe nevermind a hammer. I use a council tools rafting axe I believe it's called, I get mine from a local hand tool dealer but you could probably find them online.
thenorthman
Bailey's has a leather wedge pouch, I get 5 wedges in mine, 1 8" 2 10"s and 2 12"s plus a saw wrench.
As for a beatin device get an axe, hammer are for putting wood up, axes are for putting wood down. Mostly use a 3.5# craftsmen, but have a 5# council on deck if needed.
either tuck the axe into my belt, or recently got an aluminium axe scabbard from Grizzly, keeps the axe head down centered on my back, works pretty good, forget its there sometimes even.
I have pics but this site is notoriously hard to post pics from and I'm already late...
well that didn't work
treeslayer2003
two 10s in each back pocket and a 5lb rafting axe. any thing less and i really didn't need to wedge it.
mad murdock
Grizzly peak makes aluminum scabbards for axes/wedges/saws and a suspension system that a lot of fallers in the PNW use. Top shelf equipment.
enigmaT120
Quote from: thenorthman on June 23, 2016, 08:52:21 AM
I wonder how much time I would spend looking for my axe if I did that!
Ed Miller
Falls City, Or
danbuendgen
I am a fan of the Grizzly Peak products for wedge holder and axe scabbard, but I don't use a axe I use a hammer, I ordered the largest axe scabbard and pried it open more and it fits a 6 pound sledge well. I use 2 12" wedges. I cut about 6" off the sledge handle and it works well for me. The sledge works better for driving wedges compared to a axe, and the wedges tend to hold up longer. The axe eats up the end of the wedge much faster the a hammer does. I rarely get pinched anymore, so I don't see the need for a axe for chopping myself out of a cut. I use a Alice (military style) belt and suspenders, got the belt and suspenders used at Amazon.com for under $20. Just my .02
Husqvarna ~ TimberJack ~ Dodge Cummins
treeslayer2003
Quote from: danbuendgen on June 23, 2016, 05:52:41 PM
a true rafting pattern is almost like a hammer on the beater end. plus i can stick the axe in a nearby scrub tree.
RHP Logging
This is why I carry an axe.  From this morning. Took 2-3 minutes to chop out.  Would have been a 20 minute hike out to the truck and back for a new bar.  It doesn't happen a lot that I need to chop out but it happens.
This is why it sat down immediately.  Ugly little bugger.  It was a small job so I kinda had to cut everything.  This tree had no outward sign it was going to be like that.  The rest of the job cut out nice. Still swung her in the hole tho!
Buckin in the woods
grassfed
This is what I use. It is a 3lb cross peen hammer with a 16 inch handle. The strange looking grip works really well for me.
It has a big enough diameter that it is comfortable in my hand and those rings hang on to my fingers so I don't have to grip extra hard even when I am swinging hard and my gloves are icy.
Most of the time I use it one handed but I can swing it 2 handed for stubborn trees.
If I drive my wedge all the way in I flip it around and use the wedge side of the hammer to drive the wedge 2 inches more inside the back cut.
It will flip out but the rings stop it from falling all the way out. One thing that you can do is make a "donut" out of foam (I have used pipe insulation and electrical tape) tape the donut around the handle a 1/4 inch below the head. The foam will catch on the ring before the hammer flips out and you can still pull the hammer out and put it back in if you don't make the doughnut too big.
Mike
Plankton
Plus if you don't have an axe what are you going to use to attempt to cut skidder mainline with, only to cut yourself a bunch and put more dents in said axe then the cable! On second thought maybe I should switch to a hammer...
thenorthman
Rarely if ever get pinched bad falling (unless I'm torching off the hinge wood but thats different) its bucking that causes the most pinches, and where the axe comes in.
Also, cleaning bark off these thick skinned trees is hard on a chain, not that it ever stops me, but its something the axe is supposed to be for.
or you can use the axe as a bobber, slip it into the back cut and watch the handle start to fall, just be careful not to catch yer chain with it.
And cleaning out the face on these big ole trees, both wacking the chunk free or getting in and prying a little bit, to slipping the blade into the bottom cut to allow the chunk to fall out.
thenorthman
and another thing ;D
taking the time to find a proper falling axe one with a square pole, instead of round will make your wedges last longer.
and yet another thing...
whacking stacked wedges with a fat faced hammer is kinda tough, while the slim axe slips right in there and gets the job done.
BargeMonkey
 I used to be a fan of the long handle Estwing axes, not the same quality they used to be.  >:(  I carry a 5lb splitting axe and a couple wedges in the skidder. Sharp axe has saved me quite a few times chopping out or freeing a pinched saw. "Most" people think your crazy saying you can cut skidder cable with an axe but I've done it a few times in a pinch, had an employee yrs ago claim it couldn't be done after he kept yanking the cable off my 440D which leaves a ragged end which needs to be cut before you re-thread it in.
thenorthman
While yes it is possible to cut cable with an axe, its more then a little dangerous and it ruins a perfectly good axe.
Granted for years I did the same thing...
Then I found a morse cable cutter, miles better, and safer, they come in a verity of sizes, think mines a #2 good for up to 3/4" keep it in the crummy along with an old cross peen hammer, couple few whacks and the cable is cut fairly clean, made a video of it awhile ago.  Plus the little one I have doesn't take up much room, about the size of sledge hammer head.
Its kinda long, and never mind the fat beardy guy... but here ya go
https://www.youtube.com/watch?v=FSeyw0_U97c
thenorthman
wow.. awkward...
Works better on a stump, doesn't bounce as much... haven't had another break when I needed it for awhile. Been keeping the cut off saw on hand when the cable starts lookin iffy. That and better sourced cable doesn't break as often.
Anyway video goes on to start switching out replaceable ferule, but if memory serves it got to be a pain so I shut the vid off... never mind editing stuff that takes patience and more time then I care to spend.
Dieseltwitch
Quote from: thenorthman on June 24, 2016, 12:08:08 AM
That looks painful to use. I use the same m12 rotary tool with a small cut off disk to cut cable. Works really well. And a lot less hammering. I also use the rotary tool to sharpen my chains in the field.
Plankton
Those cable cutters are neat, I just found a super old school one in the corner of the shop now I'm not quite as excited to try it out ;)
You guys must have more patience then me I didn't even come close to doing anything to my cable with an axe. Of course I was trying to cut it off the winch drum.
I gave up and went the easy route, generator and anglegrinder.
grassfed
I keep a small Morse cable cutter in my tool bag in the skidder and my cross peen felling hammer works good with it; you just have to set it on something hard or you will drive it into the ground. BTW Labonville sells all of the Morse parts if anybody needs something.
Mike
treeslayer2003
hey Matt, i found those wedge ferrules last about 10 times longer than a knot. added benefit.
danbuendgen
Quote from: thenorthman on June 23, 2016, 09:18:49 PM
That's what your wedge is for, cut the log half way or more and stick in a wedge the cut if you think you could get the bar pinched.
As for cutting skidder cable, when it the end starts to look worn, I cut it preemptively at the landing. That way I am not 1/2 mile or more out in the woods with a ripped cable. I always have my portable air compressor at the landing, and I just cut the cable with a wiz wheel. Very fast and accurate. Tie a new not, and cut off excess cable. Back to work very quickly this way.
thenorthman
[/quote]
[/quote]
Well, these trees out here can be hard to judge the bind, 130-150' tall can do some weird things on the ground, mostly its the top that gets me...
Quote from: treeslayer2003 on June 24, 2016, 08:59:13 AM
I keep a spare on hand so the change goes pretty quick most times, that vid took forever cause I broke it the day before and hadn't removed the other end, so had to peal one off, way easier with a vice at home.
Quote from: Plankton on June 24, 2016, 06:48:14 AM
Axe not so good on the winch drum, but if you are dead set on using an axe to cut cable, mount the axe in a stump, usually by cutting a notch so the poll fits in snug, or use a wedge to hold it tight, then take a second axe or a soft faced hammer, set the cable over the axe and swing away, its fairly quick once set up, but hard on the axe, and a really good way to get bits of cast steel and high tensile wire stuck in soft bits like eyes, forearms, inner thigh, septum, throat... buddy of mine is mostly blind in one eye from doing this, with safety glasses on even.  Hence the cutter is nice cause you can keep the shrapnel pointed away from you, if any.
Dieseltwitch
Go get one of the Milwaukee M18 grinders. super useful for field work! and battery life is actually pretty good!
