Amarilla de Leche
Started by Fla._Deadheader, August 28, 2007, 05:49:08 PM
Fla._Deadheader
Sawed some 2X from these logs, today. Looks like Red Oak, but, is a dense texture.
Has Ray Fleck and wandering grain. Kinda neat stuff. It's a little more rose colored than Red Oak, but, not much more.
  Camera MAYBE Manana.  ::) ::)
  I's plumb taaard.
crtreedude
I have some of that - very nice. Pretty hard too. I thought it would make a nice floor.
So, how did I end up here anyway?
Fla._Deadheader
  It DID make the little Honda grunt.  :D :D :D
I'm having trouble seeing how nice it is. :-[ :-\ :'(
Fla._Deadheader
 If I don't fall asleep posting this, I have photos.  Man, I'm tired. Haven't worked this hard in over 6 months.  ::) ::)
  Photos aren't great. Batteries were pret-ty low.
  Stuff saws well, just hard. Logs were cut 3 years ago. Still pretty wet inside.
  I'm gonna sort through the slab pile, and pick out pieces that have sapwood on both edges, and use them for raised panel doors for Reina's Kitchen cabinets.  Just gotts cut 'em off the slabs, and lay 'em face down on a partially cut log. Saw from both sides and Bob's yer Uncle.  8) 8) 8)
  Mill owner was running the dozer around through the tall weeds while I was sawin, and my helper started yelling and jumping around.  ??? ??? ???
  Seems that a couple of Terciapelas were flushed outta the weeds and ran through the saw lot, not too far from us.
  Terciapelas are #1 or #2 Most Deadly Culebra in CR.  ::) :o :o.  Get to be 3 meters long or so, I believe.  ??? ???
  Nothing like a good day sawing in Paradise, EH ???  :D :D :D :D
  MIGHT get a photo of the set up. Great view over the Valley.  8) :) :)
A photo of that snake (or two) would be great.... ;D ;D
Interesting saw tooth marks on the first pic posted. What is the depth of cut on that piece?
Fla._Deadheader
Using an 8" Peterson, and, that's a piece of 2 X 6. Blade was needing sharpening. Cuts real smooth when first sharpened. Lots of wet mud on the logs. We try to clean them, but, well,  ::) ::)  Need to grind more often.
  THEN, there's the Ant Palaces inside the logs.  ::) ::)  Got sprayed with Ants yesterday. Had them everywhere on me. Inside the Britches, even  :o :o :o  Them Faar Ants is nasty. Hadda drop and swat, pretty much in front of 2 women. Them ants was a getting WAAAYYY too high in ma britches  :o :o >:(
crtreedude
Harold - I do believe the the more common name for that is Leche Maria  (Mary's Milk) though at times they call it Lecha Amarilla . Symphonia globulifera
Now Harold - Fer-de-lance don't get THAT big, only 2.5 meters.  ::)
They aren't more deadly, just more dangerous having a temper shorter than their inseam!  :o
Quote from: beenthere on August 29, 2007, 05:48:10 PM
I thought you was one of my buddies?  >:( ;)
crtreedude
We have the skin of one drying in one of the barns - would that be good enough? If so, I will trying to get a picture just for Jeff tomorrow of it.
Not the same as a live one, but you do what you can to make the boss happy... ;)
Fla._Deadheader
 That's the problem I'm having, trying to speak the language here. Everybody has their OWN way to say something.
  Today, I FINALLY talked the owner into switching hoses around on the front loader on the tractor. They had them, pull to raise the boom, push to tilt the forks up  ::) ::) ::)
  After SEVERAL near misses on the mill, I stopped production dead in it's tracks.  >:( 8)
  After they switched the hoses around, you shoulda seen the smiles  :D :D  NOW, it takes 1 hand to run both control valves  ::) ::) ::)  I just don't get it  ::) ::) ::)
