Wide cutting mill
Started by epiphoneprs, April 07, 2014, 12:36:44 PM
epiphoneprs
I'm looking to purchase a new mill.  My max price is $15,000.  Which mill out there has the widest cutting capability for that price or less?
Weekend_Sawyer
Not sure of the pricing but take a look at the lucas mill at lucasmil.com
take a look in their gallery, some pretty neat stuff they are slabbing there.
Jon
Imagine, Me a Tree Farmer.
tule peak timber
I have a Lucas slabber that cuts 76 or 7 inches wide and it was in that price range or a tick more.  I am pretty happy with it . A lot of bang for the buck.....
epiphoneprs
Thanks Guys.  What about bandsaws?
4430jd
Take a look at the new Woodmizer LT15 with the extra wide cutting area. Low cost and can be made portable.
ladylake
EZ Boardwalk cuts a 40" log, someone will post how far between the guide rollers.   Steve
redbeard
You will need HP and sharp blades when you chose your mill. The 1 1/4- 1 1/2 blades don't last very long cutting 32". + wide. Something to consider.
epiphoneprs
I'm definitely interested in the lt15 wide.  They say it'll handle a 36" log but I can't find any info on how wide of a cut it will make.
Weekend_Sawyer
dboyt
Norwood HD36 handles 36" wide.  I know, because I've done it.  You have to get the log on just right, and it takes a lot of muscle to turn it.  I use a hydraulic loader with a cable wrapped around the log to turn the big ones, though I recently set up an electric winch that works well.  Width of cut is officially 28", but I've taken off the guides & squeezed out 30" cuts (sharp blade, very slow cut).  You definitely need a good, solid frame, especially if you cut big logs like that with the axle under it.  With your budget, you'll be able to get the full package, chain saw, cant hooks, and flatbed trailer.
Norwood MX34 Pro portable sawmill, 8N Ford, Lewis Winch
epiphoneprs
Weekend Sawyer, thanks for the helpful thread.  So, it looks like the new lt15 wide will cut a maximum width of 32".  That's huge...Seems like it would be really tough to handle anything like that without hydraulics though.  Do you own a Woodmizer?  Everyone on this forum seems to be very pleased with them.  I've owned a TimberKing and a Hudson.  The TimberKing was great.  I sold it because it was too much mill for what I needed it for.  I did a major downgrade to a Hudson 121.  It's fine for little projects around the house but I'm planning on opening a showroom for rustic type furniture and would like to have the capability of working with larger stuff.  Thanks again for the help.
epiphoneprs
Dboyt, I'm glad you replied.  I've been wanting to talk with someone who owned a Norwood.  I love the look of those mills.  They seem very user friendly.  The main thing I like about your model is that you can start out basic and add hydraulics later on if your budget allows.  Do you like your mill?  Have you ever had any other kind?
The log handling is where the swing blade / clip on slabber mills come into their own. You don't move the log while you are sawing. That's a big issue with large logs on a manual bandmill.
The swingblade will handle cutting smaller logs into standard size boards easily enough. OK, no advantage over a small bandmill there. Difference is you will actually be happy to see 36"+ logs (instead of dreading them), and you can bolt on the slabber attachment for cutting those big live edge slabs. These can work great for the rustic furniture stuff.
Have a look at them at least.
Weekend_Sawyer
I don't have a woodmizer I have a Norwood lumbermate manual mill.
On the rare occasion I get a log I can't turn I have a skid steer with a grapple.  ;D
epiphoneprs
Thanks Ian.  I'll check into one of those.
epiphoneprs
Custom Sawyer, at this point I'm actually leaning toward the Norwood HD36.  What has your overall experience been with Norwood?
Hugh
epiphoneprs
Ian.
Is the slabber attachment just a big chainsaw?  I have a horrible time keeping chainsaws sharp just cutting firewood.  I can't imagine how I would do sawing wide slabs.
Yes it's a chainsaw. You would want a good chain grinder as part of your setup for this. They usually run a super skip chain so their are less cutters to deal with. And no matter what mill you get, it needs sharpening.
dboyt
Quote from: epiphoneprs on April 08, 2014, 10:40:44 PM
I've had several other mills.  Most recently a Timber Harvester, but sold it and bought the Norwood.  The HD36 works well for me, because I've established a niche for milling oddball stuff that no one else will touch.  The max width of cut is important, but there are other features that really sold me on the machine.  It has the most flexible clamping system of any mill I've seen, and I've cut everything from the big sycamore log pictured in a previous posting to walnut crotch flitches 30" long by 28" wide.  The frame is strong enough to handle anything I put on it, even though it is set up on wheels.  Easy to tow (1,800 pounds) and quick to set up.  Most of all, the mill just has a solid feel to it.
Operation & maintenance are very straightforward, and I opted to save some money by assembling it myself.  Lots of little things like the roller/cleat on the log stops help a lot.  I did put an electric winch on it, which helps with loading and turning.  Hydraulics are intriguing, but I've never been defeated by a log!  I've seen hydraulics demonstrated, and they look well matched to the capacity of the mill.
I've got photos in my gallery, and you're welcome to come out and give it a try.
Nomad
Quote from: dboyt on April 11, 2014, 10:34:33 AM
     I've seen the new Norwoods, but never operated one.  However, I put a lot of hours on an LM2000.  I'd stack that mill up with any manual mill out there, bar none.  I was truly impressed with that machine.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
dboyt
There are a lot of Norwood LumberMate 2000 sawmills out there.  I took my mill down to the national Tree Farm convention in Jacksonville a few years back to do a demonstration & presentation.  I brought home some nice cypress boards.  People were actually standing in line waiting for a chance to cut a board.
I'll look you up if I'm back down that way.
Seaman
Please go somewhere and watch-play with a Lucas mill. Not saying not is best for YOU, but deserves a look!
Frank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Seaman
Come see mine. I did not realize you were so close! Road trip to the mountains!
Better yet come up to the Blue Skys event on the 26th!
Frank
Woodmizer LT40HD
Semper Fi
Take him up on that Lucas mill.Them thinks are very interesting to watch.First one I saw I asked ALOT of questions.
tule peak timber
 a lot of bang for the buck......
epiphoneprs
Thanks for all the replies.  You folks are very helpful.  It would be great to go around and test these mills out for myself.  I really appreciate the invites.  Wish I could take you up on them.  I'm a busy man right now with 4 young kids and its hard to find a few spare minutes.  Maybe someday soon I'll catch up with you guys.  Dboyt, let me know if you ever come through Northeast GA with that mill of yours.  I'd love to see it in action.  Seaman, I may be able to schedule a visit in late June.
Thanks again,
Hugh
epiphoneprs
Tule Peak, that's a massive log right there.  That's what I'm talkin about.  I bet you got some wide slabs off of that thing.
Quote from: epiphoneprs on April 12, 2014, 09:58:30 PM
Nah, that's not a log.
This is a log.  :D
Some for the forum folks using a Peterson mill (similar to the Lucas) to break down a big old redwood.
This is a Lucas wide slabber, 9 ft cut.
tule peak timber
I can only sell tables so wide LOL ! Another problem with giant logs is that I don't really have the proper equipment to efficiently handle them.Back to the intent of the thread, I still think the Lucas slabber is a very versatile machine if you want to cut wide , as well as break down timber to more manageable sizes. The other option was the WM 1000 but I don't have the power for it. The lucas earns it's keep every other month....
epiphoneprs
Wow, Ian!  :o    That is CRAZY!       Do you know where that red oak was milled.  I've seen some big ones in my neck of the woods but not that big.  I wouldn't know what to do with slabs that wide.  Would the drying/handling process be basically the same as with smaller slabs (just on a larger scale)?
The story of the Redwood log is told in this thread.
https://forestryforum.com/board/index.php/topic,25028.msg357987.html#msg357987
It had ended up in  Wisconsin as an ornament outside a sawmill...
The Lucas slabber is dealing with a NZ kauri tree root ball that had fallen ~3,000 years ago, and been buried in a swamp ever since
They were selling slabs of wood like this for ~$1,000 each, off the saw. But you can imagine the table someone could make from that.
This table is one single 4" thick board. It's in the Kauri Museum in Northland.
The slabs aren't too bad to dry. Trees that grow that large seem to be some of the easier to dry for various reasons. Walnut, Kauri, Redwood, and Monterey cypress for example.
But yeah, they may not be common species in most parts of the world.
PC-Urban-Sawyer
Quote from: epiphoneprs on April 13, 2014, 12:57:14 PM
Please note that that was REDWOOD, not red oak.  Yes, I know you wouldn't expect redwood in the Midwest but that's part of the story...
Herb
tule peak timber
WOW Ian ! What do you cut your wide slabs with ?  The museum table is just BEAUTIFUL !! What did you finish it with ? How did you dry it ?I only build a couple of tables that size per year, and I have to admit my hat is off to you on that Museum piece ! The rest of the year my builds are much smaller ,but many more of them, like your rootball pic . Were you also involved in the large redwood milling ? I mill a fair amount of redwood here too and ship it back east. Please tell us more about the pics you posted.  Thanks  Rob
Wish those kauri slabs where mine  ;D  But they aren't  >:(
Just some pics I've taken over the years that show WHY people use chainsaw slabbers.  ;)
The wide slabber was being demoed by Arnold from Wood Works in Hamilton. He has a web page with some pics of the stuff he does
http://www.wood-works.co.nz/gallery.htm
I've sawn a few larger slabs on my standard swingblade, using the old trick of sawing 2/3 of the log, then flipping it over, and sawing the other side. You get one full width live edge slab from the log that way
This is a piece of Monterey cypress, that's still in the shed waiting to be made into a table.  :-[
That big table from the Museum was sawn and built in the 70s for the board room of a local brewery. When they rebuilt the offices it was donated to the museum. The top alone weighs about a ton!!
There is more pics of it in this old holiday thread, along with some other interesting things.
https://forestryforum.com/board/index.php/topic,9786.msg133192.html#msg133192
dboyt
Quote from: epiphoneprs on April 12, 2014, 09:57:20 PM
Just one trip to the Great Portable Sawmill Shoot-Out should do the trick, if you can wait until October.  It is at the Cambridge, OH Paul Bunyan Show, Oct. 3-5.  Norwood, other band & swing blade mills will be there, all running side-by-side.
Jim_Wahl
The Great Sawmill Shootout is really worth the time and money spent to attend for anyone who has any interest at all in sawmills! However, I thought they have them every other year, but perhaps there are plenty of sawmills that attend even on the years that are Great Firewood Processor Shootout years.
1997 Peterson 9" WPF since 1998
2004 Baker 3667D since 2014
Cooks Catclaw sharpener and setter
I am from Iowa, but I seem fine.
epiphoneprs
Are there any big sawmill shows in the Southeast?
POSTON WIDEHEAD
Quote from: epiphoneprs on April 14, 2014, 09:41:58 PM
Yep....Monday through Saturday....8-5 pm.....from Spring until Fall......in York County, South Carolina.  :D
Seaman
Good one David! You beat me to it.
Frank
Woodmizer LT40HD
Semper Fi
Seaman
Hugh, come up with the kids and camp at the pond anytime!
Woodmizer LT40HD
Semper Fi
customsawyer
You are welcome to come down to the sycamore project. There is only one mill but we have a good time. If you are willing to wait till Oct. there is the ag expo in Moultre Ga.
www.thecustomsawyer.com
schmism
Whats your budget for material handing equipment?
this is a great video of what happens when you try to cut a 30" (small end) frozen cottenwood that is 20' long.   You'll note that they slab a chunk off because there 5000lb forklift wont pick it up.
Gives you an idea of what its like to try to cut up a 30+ inch log and the work it takes.
https://www.youtube.com/watch?v=1523lUpCaxA
FYI loader capacities in excess of 3000lb are found on 75hp tractors and up as well as 60hp skidsteers and up.
039 Stihl 010AV  NH TC33D FEL, with toys
Good video by ElectricAl
Thanks for posting. Surprised there wasn't some blade wave.
dboyt
Quote from: Jim_Wahl on April 14, 2014, 12:43:23 PM
Right!  This year is firewood processors.  And there will be plenty of sawmill manufacturers demonstrating as exhibitors.  Good chance to see the equipment up close & personal, and maybe score a good deal on a demo mill.
epiphoneprs
Thank you all for the invites and info.  I'll have to take ya'll up on the invites asap.  Like I said, life is crazy right now. It's softball/gymnastic/baseball season.  My weekends are gone.  Poston, how far off of 85 are you? Custom, the sycamore project sounds like a blast.  Wish I could make it.
Schmism, I'm going to be purchasing a skidsteer this fall.  I figure it'll handle what I need it to.  Thanks for the video.
Seaman, we'd love that.  Looking for a good camper at the moment.
Thanks again everybody.
wwsjr
You could look at mills at the Woodmizer Open House at Newnan, GA on Satrday, May 3rd. They usually have several models to see.
Retired US Army, Full Time Sawyer since 2001. 2013 LT40HD Super with 25HP 3 Phase, Command Control with Accuset2. ED26 WM Edger, Ford 3930 w/FEL, Prentice Log Loader. Stihl 311, 170 & Logrite Canthooks. WM Million BF Club Member.
