Changing bms250 cam
Started by PAmizerman, December 01, 2020, 02:12:09 PM
PAmizerman
Has anyone changed the cam on a bms 250. How do you get it off?
Hydraulics everywhere
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
terrifictimbersllc
I changed one before but dont remember.
Went out and looked at mine in the garage, looks like take off the pusher and the stem that holds it which come from the cam.  Then there is a machine screw going through the cam,  in line with the motor shaft.  NO MACHINE SCREW.  Guessing the cam just unscrews off of this shaft.
Can't you tell anything looking at the new cam?
terrifictimbersllc
....yes, the cam (#6) threads onto the motor shaft (#3).  I think it has to be threaded since it would spin if not. There is no machine screw, the cam just threads onto the shaft and the end of the shaft is flush with the cam face.
for some reason I couldnt attach a pdf.
PAmizerman
Yes I can see that the cam threads onto the shaft but was wondering if there is some way to lock the motor shaft to keep it from turning. The shaft is round and not enough room behind the cam to get ahold of it with anything
WM bms250 sharpener
WM bmt250 setter
PAmizerman
I'll have to look again for that machine screw. Is it behind the cam?
WM bms250 sharpener
WM bmt250 setter
terrifictimbersllc
Went and looked again, there is NOT a machine screw. Just the end of the motor shaft is flush with the cam face looked like a screw to me.
Other things look different too when I put on my glasses.  :D
Because you cant hold the shaft from behind, its probably not that tight. Just tight enough to be annoying.
I dont remember but I probably put the side edge of a screwdriver in one of the two small holes in the cam and tapped that with a hammer to loosen it.  Or put a round object like a tight fitting punch or bolt in one of those holes and tap that.  Or grab the cam sideways with vise grips and tap on the vise grips.
Assume it is regular threaded direction and take it easy with a few taps, it will probably start turning and come off.
galstaf
Quote from: terrifictimbersllc on December 01, 2020, 05:07:29 PM
Hey there... I know this is an older thread, but I am looking for the complete parts diagram for the BMS250. Do you have a link to that by any chance? I cannot find it on WM's site
firefighter ontheside
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
galstaf
galstaf
Quote from: firefighter ontheside on January 21, 2024, 07:29:04 PM
i think its all in here
http://agat.woodmizer.pl/manuals/english/944_e.pdf
Hey FireFighter!
I have tried several searches to get the BMT250 (automatic duel tooth setter)... would you happen to have a direct link to that manual too?
terrifictimbersllc
BMT250 manual pdf attached
galstaf
Quote from: terrifictimbersllc on January 22, 2024, 09:48:22 AM
Fantastic.. thanks so much!
I see you are from Mystic, CT,  but how do you find them?  :D
I did PDF searches of all the WM sites around the world and came up with nada!
I would love some technical repair manuals on the LT15 electric. The instructions that came with it are extremely sparse and poor.
terrifictimbersllc
I have pdfs of most manuals for machines I own.
Got this one from Woodmizer along with all ones for my other WM items. They emailed them to me, either I called in on the phone to ask sales/tech support or I have got them by emailing one of the customer service reps.
I would not hesitate to call Woodmizer to ask for a pdf of a manual. There are usually both operating manuals and parts manuals.
One can carry all your manuals on a phone/tablet/laptop as an alternative to hardcopy.
Also anyone with a WM machine can establish an online login there, and call in and ask that the machine he owns be listed in his equipment list. After that one can just log in and look at parts diagrams with ordering information.  This is also updated with version/revision comments so that it is a "live" version of the parts manual that came with the machine, which doesnt get such updates.
