stronger
Started by coxy, December 04, 2014, 08:56:10 PM
coxy
what is stronger ironwood or elm rounds in the 5-6in diameter  and 8-10ft long   sorry said the wrong name the first time
CCC4
I place my bet on iron wood.  :)
disclaimer....I'm actually torn between both and up the anty with dogwood.
CCC4
If frozen I bet elm would bow more than ironwood and ironwood busts when frozen and you smash a tree into them.
Ironwood, if you are talking about Ostrya virginiana, is definitely denser and harder than elm.
mesquite buckeye
Is shock resistance a factor, or just straight bearing strength?  ??? ??? ???
HiTech
LeeB
What are you going to do with them. Could make a difference.
coxy
using them for steakes on forwarder log truck
1270d
Ironwood would be stronger for stakes I think.
Corley5
Beech is my favorite for forwarder stakes but ironwood is easier to find.  Sugar maple works just as well.  They all get broke.
