Woodmizer wide head debarker question
Started by JSTOM, January 15, 2019, 12:10:31 PM
JSTOM
Hello all, I'm a long-time lurker, first time poster with a question for the sawyers running the woodmizer wide head.
I got my wide head mill with the standard debarker, and just yesterday got the time to install to the new design debarker.  The blade spins toward the operator, like the old one, but the guard is now on the far side of the debarker.  I haven't cut with it yet, but it looks obvious I'm going to get sprayed with debris with the debarker running and standing at the controls.  I noticed on another thread here someone mentioned it should run the opposite direction, but Woodmizer Portland states this is not the case.  It certainly SEEMS like it should run the other way, shooting debris away from the operator and the band, but I'm not sure what to do now.
What is everyone else doing about this?
tawilson
You need to reverse the leads and reverse the direction.  Blade gets flipped accordingly.
2017 LT40HDG35 WIDE
Woodmaster 725
JSTOM
Thank you!  I kinda figured that, given the guard position and non-reverse threads on the mandrel.
Crossroads
It should have came with a different mandrel to facilitate reversing the rotation. Did your kit come with the disc to limit the depth of the debarker cut?
boonesyard
Do you get the update kit from Woodmizer? I have the same issue. Cost?
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Crossroads
Woodmizer sent out upgrade kits for the wide mills. My receipt said "good will gesture" balance due 0
boonesyard
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
John S
The original debarker on my widehead rotated away from me (the operator) and continued to trip the breaker even after I installed the depth of cut limiter. Next they sent the kit to reverse the rotation which has helped.  It seems that your mill came with this upgrade.  It is true, however, that the shield that deflects the chips is now useless.  Maybe someone at Woodmizer will read this and come up with a remedy.
2018 LT40HDG38 Wide
Stuart Caruk
The debarker is on the far side of the log from you at any rate so the log will deflect any debris regardless of which way it rotates.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Chuck White
I know that this discussion is referencing WIDE, but if it's anything similar to the standard LT40, the log will not stop ALL debris from hitting the operator!
tawilson
Especially if you have Command Control.
2017 LT40HDG35 WIDE
Woodmaster 725
Stephen1
I'm really confused. :D My debarker spins the the debris away from the log and me. It makes sense that it spins this way. Is this correct?
terrifictimbersllc
Mine sends it towards me.  In fact it is a pretty good shot sometimes gets me at over 15 feet.  :o :o
Ps I'm at the hitch end front remote.
tawilson
The old style has the debarker ahead of the pivot while the new one pulls it along behind the pivot. I think that's why they changed the rotation. I can see it in my mind but can't seem to put it in writing very well.
2017 LT40HDG35 WIDE
Woodmaster 725
Chuck White
My debarker blade spins counterclockwise, when viewed from above!
Any debris will have a tendency to be flung towards the hitch end of the mill!
Stephen1
Quote from: tawilson on January 18, 2019, 05:33:56 PM
Mine has the debarker behind the pivot and pulls, the blade spins clockwise looking from the top.
tawilson
2017 LT40HDG35 WIDE
Woodmaster 725
boonesyard
The retrofit kit just showed up, haven't had time to look in the box or at the instructions, but it's heavy so there's more in there than I expected. To cold and the weather's not fit for man nor beast, so the install will have to wait.
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Crossroads
Quote from: boonesyard on January 22, 2019, 01:54:05 PM
I don't think the instructions tell you, but the new debarker goes in the inside set of holes. If you put it in the outside position the jack is in the way when in the up position.
