LT28 wood block broke
Started by Qweaver, August 29, 2016, 03:20:34 PM
Qweaver
The wood block inside top of the mill blade housing broke in two.  Any special wood? I was just going to use a piece of white oak to replace it.  I can't think it would make any difference.
Quinton
elk42
 That will be fine because the block is only for reducing  blade flutter on the slack side
of the blade.
Machinist Retired, Lt15 WM 25 HP, Stihl 044, Stihl 311, Kubota M2900w/FEL, KUBOTA L4800 w/FEL,
Lincoln Ranger 10,000, stihl 034,
sparks
Just make sure it is the same size.
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Chuck White
Yes, I think any "hardwood" would be suitable.
If it's anything like the LT40's that have a bolt, the distance between the top of the block and the bottom of a tensioned blade should be somewhere around 1/16" clearance.
Was the block glued in, or put in with a couple of short screws?
drobertson
Did not know they used wood, I might be tempted to change it over to the 3/8 set screw like the 40's the small surface area reduces any possible heat build up and the adjustments are quick and simple,
