Debarker,, pros and cons
Started by reswire, March 19, 2014, 08:52:47 PM
reswire
I am thinking of adding a debarker to my mill, but I've heard so many people say that their debarker either didn't work well, or probably wasn't worth what they spent for it.  Most dealers will tell you that it adds milling time to each blade, but the question is how much?  I was also wondering how it may or may not affect the way the blade cuts through the log.  Any ideas, comments?
Norwood LM 30, JD 5205, some Stihl saws, 15 goats, 10 chickens, 1 Chessie and a 2 Weiner dogs...
drobertson
It really depends on what the conditions of the logs are, If you are sawing clean logs, ones not skidded or drug through the mud and muck, well I see no real need for it. I'm not sure on how add on debarkers work, I have one on my mill and use it, and it works without issue,  but at times have not when not needed. If the logs are clean, no rocks or mud or anything else, there is no need in my opinion.
POSTON WIDEHEAD
I can only speak for my debarker that came installed on my LT40.
It extends the sharpness of my blade by 75%.....just my guess IMO.
It does not get into my way.
It does not hinder the blade in no way shape or form from producing an A+ board.
This is an add on I can not or would not trade for anything.
It has paid for itself several times.
Chuck White
My mill left the Wood-Mizer plant without a debarker and one was added several years later by the previous owner!
I feel that the debarker extends blade-life by 5X.
I have sawn logs that I wouldn't have touched if the debarker wasn't on my mill!
In my opinion, the debarker is well worth the $1,000.00+ that it costs.
The only issue I've had with mine is the little up/dn motor just wasn't efficient enough to continually raise and lower the sawhead with the added weight of the debarker, so about a month ago I installed the upgrade version with a more powerful up/dn motor and a heavier duty gear box!
Since I am always sawing customer's logs most of which are dirty, I have no cons.
POSTON WIDEHEAD
Quote from: Magicman on March 19, 2014, 09:58:57 PM
Nothing like an honest answer and straight to the point.  smiley_thumbsup
customsawyer
I have had a debarker on every mill I have ever owned. Don't ask why but in the last months I have had to spend about as much time without it as I have had with it. Before the last few months I would have agreed with all above post. Since the last few months I would say that it helps about 10% of the time. Keep in mind that I am sawing logs that were used to make a logging road for the skidders to stay above the muck. Think of the worst logs you could imagine and then multiply times 50 and you are getting close to how dirty these logs are. I would have never thought that my blades would have lasted as long as they are without a debarker. All of this said I can't wait to get my debarker up and working again. ;) It might just be a warm fuzzy feeling but I miss it.
www.thecustomsawyer.com
POSTON WIDEHEAD
Debarked logs could also leave clean slabs for chipping them to sell for pulp. But one would likely have to be sawing a lot to justify the chipping. Just a thought.
Brucer
The mill I learned on didn't have a debarker. We spent a lot of time with brushes and a dull axe when the logs were too dirty.
The first mill I bought didn't have a debarker. I spent a lot of time with brushes and hoses when the logs were too dirty.
The second mill I bought had a debarker -- my choice. I would never go back to a mill without one.
Sawing through a thin layer of dirt will dull your blade after a few passes through the log. Sawing through a thick layer of sandy dirt will dull your blade before you finish the first pass.
Bruce    LT40HDG28 bandsaw
backwoods sawyer
Quote from: SwampDonkey on March 19, 2014, 10:34:41 PM
However it would take a rosary or ring style debarker like the Nicholson A-8 to clean the logs.
Debarker is really a miss-description as it is really just a mud saw. I went thru and replaced debarker from mount bolt out, it took several months during wet season to work all the kinks out. We sawed some real dirty logs during that time. I used a little hand scraper that a blacksmith made for me. Just give the log a spin and give it a quick scrapping to get the heaviest stuff off and saw thru the rest, some places mud was a couple inches thick, we went thru four boxes of saws during that time and I figure with the debarker I could have gotten away with about 3+ boxes.
Backwoods Custom Milling Inc.
Peter Drouin
I would not cut with out mine :)
A&P saw Mill LLC.
License NH softwood grader.
Nomad
     If you look at the blade on a debarker that sees a lot of dirty logs, the carbide teeth are probably pretty dull.  Now think about what the teeth on a steel band would look like.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
That is a very valid point nomad.  Those once sharp and square teeth wear down to almost nothing.
I'll be using my debarker today & tomorrow.   ;D
reswire
Are there any aftermarket debarkers available?  I don't think there are too many timberking 1600's with a debarker installed.  I'll have to call and see If they make one for my model, or if I'll have to retrofit one.  Any 1600 owner's out there with one installed??
I doubt aftermarket debarkers from anywhere other than sawmill manufacturers.  There would not be enough market to justify it.
Brucer
There was a WM owner an hour or so away from me (now retired) who did both mobile and stationary work. He made his own debarker from an old skilsaw that had a broken handle. Made his own mount, cut off the bits of the saw he didn't need, and plugged it into the wall anywhere he had 120 V.
I didn't see it but a few of his former customers were very impressed by it.
petefrom bearswamp
Debarker was the first add on I did with my old mill.
Wouldn't be without one.
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
For me the debarker falls in the nice to have category. I've used WM's and they work but I always swung the beeping thing out of the way as soon as possible. If you cut others logs for hire as my brothers above by all means get one. If you have a small mill and don't do a lot or can control how clean the logs are you  really don't need one. Probibly a good cutoff point is if you have all the sharpening equipment you do enough volume to justify a debarker. Frank C.
YellowHammer
I saw a lot of muddy, skidded logs, and I can tell when my saw blade isn't tracking in the debarker kerf because the blade will dull very quickly.  I could saw without it, but wouldn't want to.
I covered my beeper with a couple quick wraps of electrical tape, and control the volume that way.  I don't mind a nice gentle beep, beep as a warning, but hate the full volume, teeth rattling, road excavator style backup "BEEP BEEP BEEP BEEEP"  ;D. Ok, maybe I'm exaggerating a little, it's not that bad, but it just gets on my nerves...
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
dgdrls
I think they add value,  especially with a band mill.
Another option is a chainsaw mounted debarker to make a first pass
for an opening cut then work your successive cuts on the clean face.
less expensive and keeps weight off the mill.
DGDrls
giant splinter
My LT40HD came with one and I use it on every log that has bark still in place after it hits the deck, blade costs add up fast as you can see from the posts above.
I see the debarker as an all pros and no cons attachment, when a box of 15 blades costs over $300.00 plus tax and shipping it does not take long for it to pay for itself. I cant think of a more important item on a sawmill than a sharp blade when in the process of turning out quality lumber.
If you add up the cost of a new blade and then throw in the labor to change it out because it hit a rock in the first few feet of the first cut you have effectively  just entered a very exclusive group of sawyers ( the high dollar sawyers hall of fame) ............ add it up any way you want and you will be able to determine for yourself that debarkers in fact don't cost much to own and operate as well as reduce your overall operating expenses. Bandsaw blades are one of your biggest expenses and by protecting your investment and controlling your costs you are moving ahead in the proper direction.
There are few "free lunches" in this industry and for the most part we are all earning every penny of what we collect for all of our efforts, it makes good sense to take advantage of everything we can think of to control our expenses and keep our costs under control.
        GS
roll with it
Brucer
The beeping is annoying, but it's there for a reason. However ...
When I was contract sawing for a timber framer, his forklift made the same sound when backing up. Soon after I bought my second mill (with debarker) they had a couple of close calls with the forklift while backing up. Folks were getting so used to the annoying beep, beep, beep from my mill that they stopped paying attention to the forklift. True, they should have been paying attention, but the fact, some of them weren't.
So I modified my mill -- put a small plug on one of the wires to the beeper. Since I didn't have a helper right at the mill, I could safely leave it unplugged. But whenever visitors came by, I'd plug it back in.
Similar situation these days as well. If I were to leave the beeper operating all the time, I'd soon have the neighbours up in arms. So I leave it unplugged unless I have visitors when I'm sawing.
Chuck White
Quote from: Brucer on March 23, 2014, 02:18:20 AM
I agree, I installed a mini-toggle switch on the hot wire on my beeper for the same reasons and the same justification!
Peter Drouin
I just cut the wires off the beeper, I don't like it ;D
A&P saw Mill LLC.
