Damage to log turner pics
Started by gator gar, December 11, 2010, 03:21:36 PM
gator gar
Here are the pics where it stripped the top two nuts off the bolts and was working on the bottom two. I've got some grade 8 bolts in there now and it is working just fine.
  The last pic of the arm fully extended out, so no need for the rope. I should have taken a side pic.
Gator if the grade 8's don't do it you may have to step up to 1/2" you've got alot of leverage on that part ,glad it worked out well for you.Frank C.
fishpharmer
Gator, good fix.  Now we need some action shots with a big log on it.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
sgschwend
You said the nuts stripped?
According to this source there is only a 25% increase in proof load between a grade 5 and grade 8 nut.
http://www.smithfast.com/finishedhexnuts5_8.html
Steve Gschwend
sjgschwend@gmail.com
captain_crunch
Don't know anything about bandmills But here is an Idea lay a peice of 1/4 by2" wode adn as long as you can geta way with(guess 10-12" by pic) on flat part of frame weld your angle iron brackets to it and bolt it to flat part of frame. it will have to shear the bolts to move. But like I said don't have a clue what is behind frame this might impair. If you can't do this and have to go to bigger bolts I would cut a large piece of steel  on back side of frame as to spread out strain as not to bend frame rail (at least what would happen to me)
Brian
pineywoods
Gator, you will find it is possible to get a good sized log wedged in between the backstops and the fully extended claw. That's probably what happened. The amount of travel in and out is a compomise. Could have made the out farther for bigger log, but the in travel would have been limited enough that you couldn't turn smaller logs. Once you get familiar with the turner and it's limitations, probably won't be a problem. I don't have the plate across the top set of teeth on any of the mills here. You will probably take it off. The clamp does a better job of clamping with the teeth jammed into the side of the log, especially on logs that tend to want to roll a bit while you are sawing.
I have the same problem Piney describes with my two plain clamp/turner,when I get down to edging boards the clamp won't close enough to clamp them.My solution was easy just put a piece of scrap wood between the boards and the clamp.Possibly with the Pineywoods turner you could use two claws held by a pin one for small logs one for large,or mayby one that would turn around or flip over. Frank C.
gator gar
Quote from: pineywoods on December 11, 2010, 10:51:05 PM
The little plate wasn't my idea, it was my buddies. I just went along with it, but Boman and I already discussed taking it off. I'll hit it with a cut-off blade on my grinder and take it off. I looked at Bomans mill and they have the turner welded to his frame. So, as I said earlier, I'm going to weld a couple of short passes on mine, to help re-enforce it a little.
pineywoods
Bandmiller, we think alike. I have an extra hole so I can move the clamp in closer for small logs, but I seldom use it. Instead, I keep a couple of 3 ft 4X4 handy and just chunk one between the boards and the clamp.
Gator, it's just a matter of time before you saw it off with the band anyway  ;D
gator gar
Update......... The little plate is coming off tomorrow. It made turner slide up the log, as I was trying to get a bite. The turner is working just fine now. We weighed a red oak log that was 2200 pounds and put it on the mill and it rolls it like it is nothing. Too cool.
Sometimes it's not just the weight.  An odd shaped log can really test your metal mettle  ;)   :)
