AVAILABLE
Author Topic: Cracked oil tank MS311  (Read 567 times)
Offline KamHillbilly
« on: January 14, 2018, 09:04:48 AM »
Cutting firewood the other week , -30C the chain grabbed a snipe and threw it against oil tank now oil tank seems to have a leak right where it seems that the composites are molded  together . Found a new one on EBay looks like a challenge to change . Anyone else had this issue I guess this is what I get for not coughing up the extra 300 for professional saw .
Homemade Bandmill ,Clark 664b ,Case 780b ,Jonsered 670,630
Offline dougand3
Re: Cracked oil tank MS311
« Reply #1 on: January 14, 2018, 10:50:03 AM »
It will be very time consuming to change chassis/crankcase. Every part has to come off and re-installed on new chassis. And the expense of a new chassis.
I'd look for a plastic repair method...plastic weld, plastic epoxy, heat, whatever. Search web for chainsaw plastic repair.
Husky: 272xp, 365, 261, 61, 55 (x3)
Stihl: 036, 026, 011AVT
Poulan: 4218, 2000
Offline ZeroJunk
« Reply #2 on: January 14, 2018, 11:30:58 AM »
I think I would just let it leak. Store it bar up or whatever.
Offline Texas-Jim
« Reply #3 on: January 14, 2018, 03:06:06 PM »
I dont know of after market source and new housing is about 125 bucks plus its an extensive job as doug said. Can be plastic welded but you have find a person with plastic welder. JB weld makes a two part plastic menter in a syringe type applicator that work half way good if its clean ans scuffed up.
What we do in life echoes through eternity.
« Reply #4 on: January 15, 2018, 12:55:35 PM »
I have a stick that the pipeline used to cover nicks in coating on pipeline you heat with torch going to give that a try first . Fingers crossed?
Offline joe_indi
  • The older I get the more I learn
« Reply #5 on: January 20, 2018, 11:37:41 AM »
Could you post a picture of the damaged area
« Reply #6 on: January 20, 2018, 08:29:46 PM »
Ill take a few pictures tomorrow
Cracked Gas Tank
Started by Erick on Chainsaws
Last post September 27, 2004, 07:05:36 PM
by Frickman
WM gas tank cracked
Started by Qweaver on Sawmills and Milling
Last post June 26, 2013, 04:48:59 PM
by mesquite buckeye
Husky with cracked gas tank
Started by TessiersFarm on Chainsaws
Last post February 02, 2013, 01:35:28 PM
by TessiersFarm
stihl ms311
Started by sawwood on Chainsaws
Last post March 16, 2017, 09:44:06 PM
by DelawhereJoe
