346XP/NE & 372XP X-Torq Unlimited Coils
Started by XP_Slinger, September 08, 2015, 02:46:42 PM
XP_Slinger
Hey All,
   I am considering installing unlimited coils in my 346XP/NE and 372XP X-torq so I can accurately tune them.  When I tune them to 4-stroke prior to bumping the limiter they are noticeably down on power with slower throttle response.  They both feel good when tuned against the limiter however I don't like not knowing for certain whether or not they're too lean.  For those that would ask, my motivation for this is simply getting the best power out of my saws without running them dangerously lean like they are when set up from the factory.  Both saws are muffler modded and I would appreciate your inputs and patience as I am only just beginning to take my saws beyond factory configuration.  Regards...
Josh
346XP/NE
357XP...ported by MeDremel
372XP/XT...ported by A. Burr
Homelite (Solo) 340
I'd rather be in the woods than on this computer.
weimedog
Plug checks are a great way to tell after some run time. Tach's are cheap too... can save a lot of hassle.
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
XP_Slinger
Agreed, I have not gotten a tach yet and I need too.
346XP/NE
Homelite (Solo) 340
Spike60
Josh, you really don't want to be bumping the rev limiter when tuning saws with speed restricted coils. Once you hit the limiter, you never know how much is too much cause it will sound the same as you continue to lean out the adjustment.
Both saws take the same unlimited coil. Only thing you have to do is trim the wire to the correct length for each saw.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
XP_Slinger
SPIKE60,
    What you stated is exactly why I don't like tuning with rev limited coils.  If tuned to the limiter, you're guessing, if tuned under the limiter, you're loosing power.  I will be ordering a tach and non-limited coils for both my saws at the end of this week.  Thanks.
Josh
346XP/NE
Homelite (Solo) 340
49er
  I put an unlimited coil on my 365xt for the very reasons sited. However, I know Spike recommended keeping the R's around 13K. Mine didn't hit the limiter till 13.3k.
  That big piston may put a strain on the lower end and doesn't stress go up with the square of the RPM.
Husqvarna EC390 365xt
Jonsered 2188 2165 2260 2253 70e
Redmax GZ4000
XP_Slinger
49er,
    You illustrated the #1 reason I need to get a tachometer.  Just because the saw hits the limiter doesn't mean it's not turning too many RPM's.
346XP/NE
Homelite (Solo) 340
HolmenTree
Welcome to the site 49er !
I love your Sabre jet avatar.  :)
49er
Thanks for the welcome HolmenTree.
That is one of the planes I worked on in the Navy. It is an A7 CorsairII from VA-87. About 1972.
Redmax GZ4000
XP_Slinger
49er,
    Thanks for your service and welcome.  I am 16 years into my Air Force career, I worked on F-15's and F-22's.  I've been flying a desk for 6 years and still miss the smell of JP-8 in the morning.
346XP/NE
Homelite (Solo) 340
49er
Jp-8 we only had jp-5. After 12 hours on the flight deck I smelled just like it. :D
Redmax GZ4000
XP_Slinger
Ground crew cologne...LOL!  My wife use to love that!
346XP/NE
Homelite (Solo) 340
49er
Quote from: XP_Slinger on September 09, 2015, 03:50:58 PM
49er,
Wow, F-22's I saw one at Thunder Over Louisville do things I never thought a jet could do. It was very impressive.
  My Dad was an Aviation Chief in a B-17 squadron and spent all four years of the war in the Aleutian Islands, now that is service.
Redmax GZ4000
XP_Slinger
Now THAT is a proud family history.  Respect.
346XP/NE
Homelite (Solo) 340
