Live edge siding
Started by John S, October 06, 2016, 12:18:28 PM
John S
 I was contacted by a real estate agent regarding a customer who wants to put some live edge siding to replace vinyl on an existing structure.  Is this type of siding normally tapered or just flat sawn?  Any help is appreciated.
2018 LT40HDG38 Wide
DDW_OR
69bronco
Last batch I did I cut at 3/4, dried to about 5/8. Flatsawn.
Sawmill Man
 I saw a three sided D log and then flat saw. this gives you control over the average width of the siding unless the customer wants to straight edge the taper out himself. If the logs had no taper then straight edge would not be necessary.
"I could have sworn I went over that one with the metal detector".
Joe Hillmann
I flat saw it (no taper)  and have a live edge on both sides of it.  That way when putting it up I can decide which side I like better.
