Swing Mill Blade Coolant
Started by Firebass, April 26, 2007, 12:38:13 AM
Firebass
 ???Ok,  Now as some of you know,  I have entered this forum about as green as a tree frog.  And I've asked some of the most basic questions there is to sawing with a swing mill.  But! Now I've got a few hours on my homemade swing mill and I'm trying to figure out the coolant subject.  I'm using a Lucas blade and I've been cutting dry Douglas fir.   So dry, That I almost have to wear a dust mask if theres no breeze.  I have used no coolant on my  mill because  I haven't noticed any heat  or build up on my blade until today when I started cutting some fresh (still alive) fir.  I got some yellow temper near the rim of my blade.   So What about coolant? Is it really necessary or is it just a dust collector? or does it lube the blade so much that it doesn't get hot?  I can't wait to hear the theory about it.  Because I just don't know.
Firebass
solodan
Water or soapy water! You need to keep it cool.
Captain
It REALLY depends on what you are cutting.  Dry and really "pitchy" species usually require water.  I've only used soap when cutting "Pitch Pine", a really ultra sticky variety up here with greenish bark.  It is also necessary when there is inadequate side clearance on the blade teeth to reduce the possibility of overheat, as an example when the teeth have been ground down more than 1/2 way.  Water use also depends on your sawing feed rate.  When I'm running wide open, typically there is water running on the blade.  At the end of the day in the last tank, I'll add dish soap to keep the algae from growing.
I use very little if any water in the winter time on frozen, fresh logs.
Captain
brdmkr
Firebass, I use Lucas blades too (good thing since I have a Lucas mill).  All I have ever used was water, but I NEVER run without lube.
Firebass
Quote from: brdmkr on April 26, 2007, 08:50:44 AM
Thanks for the reply.   I think I'll have to add the watertank to my mill.   What is a good sign of the right amount of water?  where is it applied and Does it trickle thru the holes in the blade so it can reach both sides?
Firebass
brdmkr
The water drips very near the hub holding the blade.  I set it to just a slight trickle before I fire up the mill.  I then just pretend it is a Ronco oven.... I set it and forget it.  I do refill the jug when needed.  If you need some pics of how it is set up on the Lucas, let me know and I'll get some for you.
Firebass
Quote from: brdmkr on April 26, 2007, 10:53:15 PM
Ronco Oven,  :D :D :D  That was my next question.
Dakota
Firebass,
What everyone else said.  Here's an idea for taking and storing water near your mill.  Maybe even use one to act as your tank.  Anyway, my wife discards these, they've got soap left over in them, so I just fill them up and keep them for refilling my tank.
Dave Rinker
Firebass
Quote from: Dakota on April 27, 2007, 10:29:08 AM
Firebass,
Great Idea
Thanks,
Firebass
urbanlumberinc
Try using a capful of pine sol in your cooling water when sawing softwood species.  Pine sol, like the name implies, dissolves pine pitch better than anything I've found.  I use it right out of the bottle to remove any buildup at the end of the day.
