General Forestry => Sawmills and Milling => Topic started by: wolf nemeth on July 15, 2017, 09:33:18 PM
Well, it happened again.....my log clamp stayed 'up' despite the lever telling it to go down. So I a) reversed (180 degrees) the little piston attached to the lever b)made sure the hose to the clamp piston was flexing c) greased every nipple in the area and d) removed the clamp piston from the clamp assembly.
The piston worked perfectly once I detached it. So the fault was in the big cylinder with the clamp on top. I assume that it should move up and down freely, but it did not. I could back it down, about 1/2" at a time by banging in it with a a pipe wrench, but that seems like an extreme and possibly destructive strategy.
I was left wondering if somehow I had gotten an ever-so-slight bend in the cylinder which cause it to bind in that square metal housing which it passes through in its up or down travels.
So, hoping for a miracle, I rebolted the piston to the clamp, and now the unit works (although sometimes I have to go up before it goes down).
Isn't that big piston supposed to slide freely through its housing? What's in that housing? Snakes? I'm afraid to open it up!
What mill is this on?
OOps! I meant to mention...it's my Woodmizer HD40.
When I had the same problem with the horizontal tube, ATF helped a lot. There is nothing special in the clamp box, just brass tubes and seals.
My clamp sticks once in a while, up/down usually, side-to-side sometimes. I spray them with a dry teflon lube when it happens (or whenever I grease the mill) and the problem goes away.
Sounds like pitch residue on the cylinder . I always have a squirt bottle of ATF , but if yours is that stuck I would soak it in blue creeper first . It's not a serious problem just a part that needs a little lube now and then .
Thanks, guys. I figured it was just seals but was amazed how stuck the part was. I'll try dry lube first....
