Small MIG welders
Started by Qweaver, December 12, 2014, 07:04:44 PM
Qweaver
I bought a Lincoln 180 and finally got to try it out today  welding 3/16" x 1" strips on the door of the 1/4"  pipe that I'm using to build a BBQ.  I've done hours of MIG with large 3 phase hot start machines but this was my first with a small machine.  This is a $1000 machine not one of the cheapees so I expected good results.  I could only buy CO2 and it worked fine.  I started with the .025 wire that came with the machine and I was a little disappointed  with the penetration.  It would be really easy to cold lap with this wire.  I switched to .030 and this was much better.  I used 75/25 mostly on the big machine but I think that CO2 may give better fusion on this machine.   I am satisfied with this machine for doing light work...but no xrays please.  I'm glad I didn't get a less capable machine...this one barely makes it.
I have a Lincoln SP175-T. I've had it at least 10 years. Runs on 220,it's a small one. But does fine for repairing and building the things that I use. I built a metal box,and mounted that on a 2 wheeler. I had plans to make a couple draws,only made one.  ::)  I have about 50 feet of heavy gauge wire coiled up on the back. I just unwrap what I need to get to the project. Gas was not common around here years ago,so I went with no gas,flux core wire. Most of my welding is done outside,so it helps that way. I have used gas at my other job and I know it does a much cleaner job.
snowstorm
i use argon with 2% oxygen. works good. i have a 175 miller. havnt used it in a couple years. thats when i bought a 250 esab. i really like the esab
Qweaver
there is an argon shortage and  I can not buy it right now, but the co2 is working fine.
shinnlinger
I have a 181 thermal arc that used to work real well but it stopped feeding and the shop said it needs a new motherboard and is obsolete.   I went back to my Lincoln tombstone.
Shinnlinger
SPIKER
I have a CENTURY 120volt that will do 90~120amp works well enough & have done a good amount of welding with it.   Sheet metal and have even welded up 1/4" with it in couple passes, the feed is not the best but I bought it in 92 & put a couple 10 lb spools & 2 lb spools thru it, 030 seems to work about the best.
  I have found that the .025 wire is great at cutting glued in windshields out really well!
I also have a tombstone AC/DC for most everything else.
mark
I'm looking for help all the shrinks have given up on me :o
scsmith42
I have heard a lot of good things about the Miller 211 too.
Tom's 3638D Baker band mill
pine
Quote from: Qweaver on December 12, 2014, 09:03:28 PM
That is news to me.  Must be regional thing.  No problems out here.  Helium  has gone way up in price if you need it to TIG with a DC only tig machine.  Argon is still cheap and plentiful at the LWS.
