Eaton winch break not releasing. Any ideas?
Started by Mountain_d, February 04, 2018, 09:07:36 AM
Mountain_d
I have a 1978 Timberjack 230E with Eaton winch. On my last run last night I could not winch in the last 30 feet of mainline. I also could not release the winch. Cable is not jammed on the reel. I am assuming the the brake is not releasing? Any ideas what is causing this? I am going to work on it today and hope to have it going for tomorrow. Hopefully something simple! Any ideas to shorten the troubleshoot would be appreciated. Thanks. Mountain.
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Maine logger88
I would check the pressure to the brake cylinder it's supposed to be around 550psi when mine did what yours is doing it was the relief
Mountain_d
Thanks Mainlogger. I just came in from fixing it. Ended up being mainline bent around the friction adjuster on the bottom of the winch. I could not see it until I crawled under. Simple fix but put a heck of a pig tail on my mainline. I have it stretched out on a tree now to try get the twist out for tomorrow. Amazing the thing it was caught on did not break! They sure built these things to keep going! Thanks again. I will keep your cure in mind for another day. Mountain.
Maine logger88
