General Forestry => Chainsaws => Topic started by: thumper on November 28, 2009, 12:54:44 AM
Title: 357xp/2156 or 359/2159
Post by: thumper on November 28, 2009, 12:54:44 AM
hello everyone, great site youve got here!  please dont be irritated by my common question. ive read countless threads about the difrrences in these saws. for the most part im sure id like either of these saws. i have a 2165 for firewood, larger felling and bucking. a 2150 for everthing else. i really like both saws , i find the 2165 to have power to do anything, but tends to get heavy in the limbing and just walking around area. the 2150 is a great machine for limbing but of course it dont have the power youd want for medium felling and limbing hardwood.  i cut alot of poplar and it seems to suck up the power. the job i do the least is spruce/fir hemlock so small limbing isnt so frequent . but not unheard of.  there is alot of price diffrence in these 2 saws and i dont want to by saw not suited for me .would i benefit the most from the torque of the 59s or the all out rpm power of the 2156/357xp?   ???javascript:void(0); ???
Title: Re: 357xp/2156 or 359/2159
Post by: Cut4fun on November 28, 2009, 06:03:02 PM
I have a 357xp and a 365 special. There could be only a pound to 1.5lbs difference in them PHO. Something in 12.??  (cant remember) and 13.6lbs.
If you want a limbing saw and smaller bucking saw. Look at the new 50cc 346xp 11.??lbs with the grey side cover. If you want to save even more weight and more toward limbing old 46cc 346xp 10.??lbs with orange cover.
Post by: thumper on November 29, 2009, 01:01:48 PM
i got rid of my rough old 346 to get my 2150.  the 2150 has more torque and i like that.  i do like the 346 for small limbing though. id like to get 1 powerhead that will do it all, no more hauling 2 diff saws around! lol
Post by: sawguy21 on November 29, 2009, 01:15:08 PM
Are you a weekend warrior or cutting for a living? The 2156/357XP are high performance saws designed for the professional user. Here they are popular with pulp cutters and spacing crews. The 359 is a nice all around saw good for the farmer/rancher/fire wood cutter. It would be a good choice unless speed is important.
Post by: thumper on November 29, 2009, 01:29:45 PM
i usually work by myself or with one guy and use a john deere 440a cable skidder. we do small/medium woodlots cutting just about everything from mostly poplar to firewood. i do like speed but that isnt as important as doing the job right every time! i wonder if the 59s will hold up like the full professional 57s.
Post by: sawguy21 on November 29, 2009, 02:11:24 PM
The 359 is built with the same quality as the 357 which is the hot rod version.
Post by: Rocky_J on November 29, 2009, 02:27:18 PM
I think the crank is different on the 359, as well as the porting.
Post by: chucker on November 29, 2009, 03:10:24 PM
i use the 2054 for limbing if theres a lot of trees to be done . for all around limbing and bucking i find the 2159 not that bad . weight to power ratio of these two saws are about nill. if i am limbing jack pine at 8" common and doing say 2 cords or more a day then i stick with the 2054.... bigger just the 2159... all said between the 2 saws you have to make extra trips back and forth to retreive another saw thats not at hand. kinda like having a golf bag full of saws!! ?lol
Post by: Cut4fun on November 29, 2009, 05:49:14 PM
Here is my woods ported 357xp by Dave Neiger and then a friend did a little more making a domed piston for it.  Saw has seen very little use because of it's bastard size of 57cc IMHO. I usually grab my 49cc saws for smaller stuff or  65cc and up cc saws if I need a saw for bigger stuff.
If you are near Ohio your welcome to come take a test drive. Everything I own has a price if it's right  ;). A 359 can be made the same way with it's 59cc non-mahle topend. Just choose your builder wisely, they are not created equal at finding gains in a work saw.
357 has bells on the crank. So if you remove the topends and bells off the crank they are identical after that.
http://www.youtube.com/watch?v=v_PLLQ2N_3I
http://www.youtube.com/watch?v=IZJeepcpaN8
Post by: John Mc on November 30, 2009, 02:59:56 PM
Nice! what kind of wood were you cutting there?
Post by: Cut4fun on November 30, 2009, 03:12:08 PM
Just dried out poplar in 10x10 top and 8x8 bottom cants.   I use that for all my testing for gains in timed cuts so the wood is uniform.
Its not all about WOT rpm like some will let you believe. It's about rpm held in the cut  ;). If you noticed I had the saw running  below stock rpm's 13.8k and on the rich side.
Post by: SawTroll on December 12, 2009, 11:33:17 AM
Yes, the 357xp has "fillers" on the crank - and the cylinder is different both in design (porting) and quality.
Post by: SawTroll on December 12, 2009, 11:50:18 AM
I have a 357xp and a 365 special. There could be only a pound to 1.5lbs difference in them PHO. Something in 12.??  (cant remember) and 13.6lbs. ......
It is less difference than that for the empty powerhead - but the bulk difference, larger tanks of the 365 etc makes it feel like more difference in practical use.
Post by: nmurph on December 13, 2009, 12:32:01 AM
i have a 359, a 357 and a 262. they are all within an ounce or two of 13lbs and cut very similarly in wood under 12". above that, the power of the 262 takes over as the wood increases in size.
Post by: thumper on December 13, 2009, 12:41:18 AM
Do you think the 359 does any better than your 357 in wood 12" plus? thanks
Post by: nmurph on December 13, 2009, 12:47:32 AM
the 359 is the slowest in any size wood, but only by a small margin in wood less than about 10". as the wood gets larger, the 357 and 262 start to show their power advantage, with the 262 having an edge, and that edge getting larger as the wood gets larger.
Post by: thumper on December 13, 2009, 12:57:16 AM
wow, i thought if there was anywere the 359 were better, it would be in the bigger stuff. do you find the 359 better in any area?
Post by: thumper on December 13, 2009, 01:00:00 AM
i wish they still made the 262. i think its crazy to have so many saws that are so close to each other. back in the 80s and 90s i think my dealer carried three saws the 254, the 266 and 268.  and he could special order a 281.
Post by: nmurph on December 13, 2009, 05:21:20 AM
359-3.9hp
357-4.4hp
262-4.8hp
i've got a 281 also. it is heavy, but it is in a different league altogether. i think it is rated at 5.7hp. it is not as fast as my 7900's, but i enjoy running it for a change.
Post by: nikocker on December 13, 2009, 07:10:19 AM
Post by: John Mc on December 13, 2009, 08:30:48 AM
Price.  ;D
I do wonder about durability... seems as though cranking more power out of a smaller engine would tend to shorten its life. But then I've not heard any complaints in this regard for the 357, so maybe it's not an issue?
John Mc
Post by: SawTroll on December 13, 2009, 05:01:07 PM
That is true!   8) 8)
Post by: SawTroll on December 13, 2009, 05:07:12 PM
The 359 just is a cheaper and inferior saw - no miracles will happen (unless it is modded)..... ::)
Post by: thumper on December 13, 2009, 06:15:49 PM
well, im not racing against anyone i just want to use my saw everyday without tuning and fiddling at the jobsite. also not so happy with saws that require w.o.t all the time to cut anything without bogging. i will use my 2 saws 2150 and 2165 for the next few weeks and then i will be buying a new jonsered 2156 or 2159. ive had a 346oe in the past and didnt really care for it,  im not so happy with the hsqv dealer around here. so a 346 is out of the question unless the new one is as powerful as the 56/ or 59. even at 1lb or so quoted less , i think it will be less strain after carrying a 2165 all day.
Post by: Cut4fun on December 13, 2009, 06:22:07 PM
Thumper where are you located? That like new 357xp that is woods ported is FS  in my video's I posted in this thread. Cost is less then a new 357 for PHO.  I'm wanting to get a alky saw built and the 357 hasnt seen any real use since 2004. Just a hobby cutter here and use it for gtg's.
Come take it for a test if you are close.
Post by: thumper on December 13, 2009, 06:28:45 PM
Id love to try that 357 but im in northern maine, with dialup, so i cant even watch the video!  :'(
Post by: Cut4fun on December 13, 2009, 07:02:06 PM
Dial up on my end takes about 10 mins to load 30 sec video. I just start download leave come back and hit replay. Good Luck.
Yep little far for a test drive, sorry.
