Author Topic: Fungus/mold on White Pine boards  (Read 2142 times)
Offline rlueth
« on: February 07, 2018, 02:54:59 PM »
I saw some beautiful white pine in N. Minnesota.  It's nice and clear and gorgeous looking wood, fresh sawn.  Problem is, as it dries many of the boards get a blackened area.  I assume this is a mold or fungus that invades the fresh sawn wood and stains it black.  I've even put the fresh sawn wood into a shed to keep the elements off of it but it still gets that stain. It goes quite a ways into the wood, tough to plane it out.  Can someone shed some light onto this problem and specifically how I can prevent it ?  Was wondering about spraying some diluted bleach solution onto the green wood ?  Thanks much.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Fungus/mold on White Pine boards
« Reply #1 on: February 07, 2018, 03:02:41 PM »
When I worked at Grizzly tools we got in a bunch of tool crates that
got the black  fungus. We sprayed the crates down with bleach and
all the black went away...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline kenfrommaine
« Reply #2 on: February 07, 2018, 03:48:22 PM »
Is the wood just dead stacked, it needs to be stickerd for air flow. Especially with Pine.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: February 07, 2018, 04:09:22 PM »
Absolutely, the lumber needs air circulation until it is down to around 15% mc!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Don P
    • Calculator Index
« Reply #4 on: February 07, 2018, 04:51:40 PM »
Keeping the elements off is a good thing but that cut down on the airflow for drying. Keep it away from walls, open all the windows and doors and keep a fan on it until it dries down below fiber saturation, when you make a fresh cut and don't see moisture inside. Alternatively outside in a breezy area, well off the ground, facing so the prevailing wind goes though the pile with well weighted tin on top to shed rain will work. If you are staining you're drying too slow, if the wood is checking you're going too fast, drive right down the middle between those two ditches.
Offline ncsawyer
« Reply #5 on: February 07, 2018, 05:35:12 PM »
Here in NC, I have cut green pine and stacked and stickered under an open shelter, only to come back a week later and see that most of the lumber had turned green.  It is hard to keep pine from molding, even when it is stacked with good air flow. Hardwood is doesn't mold nearly as bad.
You can try spraying a fungicide and an anti-stain agent on the lumber when you stack and sticker.  You can use something like AntiBlu XP64.  I have never used it personally, but know a guy that uses it in a dip tank and it works well for him.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
Offline MrMoo
  • Do you have a spare log dar
« Reply #6 on: February 07, 2018, 05:58:13 PM »
Sell it as naturally stained wood. Its organic too.  8)
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #7 on: February 07, 2018, 06:08:00 PM »
I find it nearly impossible to keep the sap wood from molding on white pine.  I've put boards that had dried for a year up on the exterior of a shed and the sap wood will still turn dark over time.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Chuck White
« Reply #8 on: February 08, 2018, 07:37:48 AM »
It will help when you're stickering your Pine if you keep the stacks narrow, like only three or four boards wide!
Just make it easy for the air to circulate through the stack!
~Chuck~
Offline fishfighter
« Reply #9 on: February 08, 2018, 07:52:14 AM »
This for sure. Bleach helps too! One cup to one gallon works for me. Another thing that helps is scrapping all saw dust off the boards with a sheetrock knife. Air flow and more air flow is the best.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #10 on: February 08, 2018, 08:03:08 AM »
Sticker the wood and put barrel fans on it.  Lots of forced air.  Scrape the sawdust off.  The fans will dry the wood in a couple weeks to where they won't stain.  Narrow stickers also help, or profiled in the shape of an "H".
HobbyHardwoodAlabama.com
Offline Alligator
  • Born behind the slab pile, have turpentine blood
    • Alligator Casey
« Reply #11 on: February 08, 2018, 08:09:46 AM »
Try a salt  (1 cup)and pool chlorine (1 cup) solution mix in water (5 gallons). The chlorine will bleach but evaporate the salt will stay in the wood and inhibit  new mold from forming.  As stated good stickering and air flow are a must.
Esterer Sash Gang is a  Money Machine
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #12 on: February 08, 2018, 06:47:02 PM »
I just try to get lumber ahead before Aug. For me, that's the only time of the year I have trouble.
As far as putting stuff on the pine to stop it, I don't, What happens when a customer runs the lumber in a saw or planer. The dust with the stuff in it gets on or in my customer.
He or she gets sick or a rash from the stuff I put on the lumber. It might come back on me.
All lumber here is 100% natural.
Offline rlueth
« Reply #13 on: February 12, 2018, 09:04:00 PM »
Yes, I do sticker the lumber, use 3/4" by 3/4" stickers.  Most dries outside, just put some sheets of tin on top of it.  I do stack the piles pretty close together so that would certainly limit the amount of wind that gets at the pile.  Maybe I'll try spacing the piles out so more air can blow thru it.  Think I might experiment a little with some of the "spray on" ideas. At least I'm not the only one experiencing this issue.  Thanks for all the feedback.
Offline Brad_bb
« Reply #14 on: February 12, 2018, 11:01:51 PM »
Bleach/water solution can help.  Not more than 5% bleach.  I've read studies that 2% is just as effective as 5%, and more than 5% bleach is of no additional benefit.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #15 on: February 12, 2018, 11:04:22 PM »
This is true Brad....from experience.
Online samandothers
« Reply #16 on: February 13, 2018, 10:47:24 AM »
Seems I read too that too much bleach can break down the wood and cause the fibers to fuzz up.
Offline Don P
    • Calculator Index
« Reply #17 on: February 13, 2018, 05:20:29 PM »
Bleach, and salt, both pulp the wood. They aren't particularly good for it, or for applying finishes to that surface later. I could say about the same thing for mold too though. Salt also corrodes fasteners, that would be the meat house floor I rode to the ground when I stepped inside. The nails were all rusted away and the bottom ends of the studs was just loose fibers. I brought a piece of that wood home and mice seemed to enjoy cribbing on it for the mineral. That was many years worth of salt.
No Mold on my Pine Boards
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post September 13, 2013, 06:39:34 PM
by Dave Shepard
Green and white mold on Eastern White Pine
Started by AnthonyW on Drying and Processing
Last post September 14, 2015, 09:15:28 PM
by AnthonyW
Question about mold/fungus eradication and prevention
Started by Paschale on General Board
Last post November 02, 2010, 04:09:57 PM
by beenthere
Now that logs are peeled what should I use to prevent mold and fungus
Started by Edvantage on Timber Framing/Log construction
Last post June 02, 2019, 07:32:54 PM
by Don P
