Author Topic: Walbro Fuel filters unreliable?  (Read 355 times)
Offline MNBobcat
« on: February 12, 2018, 07:58:30 PM »
Hi Guys,
I have a Dolmar 6100 that I've been having on-going problems with it not running right.  The engine RPMs cycle up and down and sometimes by as much as 50%.  Its still under warranty.  The dealer put a new carb, new fuel pick-up line in the tank and a new fuel filter on it.  Ran good until the 3rd tank and it's back to it's old tricks again.
I replaced the fuel  filter once, prior to the dealer replacing it.  It seems like with a new filter it will run fine for a tank or too.
The fuel filters it uses look like this:
I am wondering if any of you have had issues with that type of filter?  When I got it back from the dealer I dumped all the fuel out of my fuel can I got brand new non-oxy fuel with new stihl oil.  So I know that it's not fuel contamination.  At least not that I could tell.
I'm considering trying a new bronze filter that looks something like this:
The above isn't exactly what I'm considering but its close enough to give you an idea.
First I would like to hear if any of you have had ongoing problems with walbro filters?
It may not be the filter at all but the dealer is 2 hours away and trying a new, different style of filter, is a quick and easy option.
Thanks!
Offline dougand3
Re: Walbro Fuel filters unreliable?
« Reply #1 on: February 12, 2018, 09:06:50 PM »
Never seen a fuel pickup like the brass one. I don't have trouble with 3 different kinds of filters that I order online...some 50 cents each. Search "chainsaw fuel filter" and get 2 of each kind and try.
Husky: 372xt, 272xp, 61, 55 (x3) Stihl: 026, 011AVT Poulan: 315, 4218 (x3), 2375, 2150, 2055, 2000 (x3) Homelite XL
engine filters,oil ,fuel,air,
Started by Stump Jumper on General Board
Last post February 06, 2006, 01:33:00 PM
by Stump Jumper
353 fuel filters not full
Started by jd540b on Forestry and Logging
Last post February 24, 2015, 10:20:20 PM
by treeslayer2003
353 detroit not starting after changing fuel filters?
Started by logman81 on Forestry and Logging
Last post November 29, 2013, 07:44:20 AM
by logman81
1964 TJ - Struggling to bleed new fuel filters
Started by nurtons on Forestry and Logging
Last post December 15, 2013, 07:19:16 PM
by Upnorth
