Author Topic: Stihl chain cover pads..  (Read 734 times)
Offline realzed
  • Old Fart but - I'm new!
« on: February 15, 2018, 11:34:12 AM »
Can anyone confirm if the plastic wear bumpers or pads inside the chain cover (top and bottom - near the front edges) for a Stihl 026, are the same as the 260 or other models? I need a couple for my son's 026 and not quite sure what they should be actually referred to as, but I'll call them rub bumpers or pads and appear ntended to keep a loose chain contained so it won't hack up the chain cover case if it gets too loose or wayward.
Thanks - Randy
Offline sablatnic
Re: Stihl chain cover pads..
« Reply #1 on: February 15, 2018, 11:43:05 AM »
They are the same for 026 and 260.
Offline realzed
« Reply #2 on: February 15, 2018, 12:03:43 PM »
Thanks from the look of the hole they push into I thought that might be the case!
Stihl MS 660 cracked mount near the chain gaurd cover, left side
Started by tamarack64 on Chainsaws
Last post June 19, 2015, 06:26:52 PM
by weimedog
Jonsered 2065 saw chain cover plate
Started by Dana on Wanted
Last post November 20, 2012, 02:13:25 PM
by Dana
Stihl air filter cover
Started by timberfaller390 on Chainsaws
Last post February 08, 2009, 01:28:10 PM
by Rockfarmer
Air filter & cover replacement for stihl 440
Started by davefrommd on Chainsaws
Last post June 19, 2004, 12:37:49 PM
by incognitive
