Author Topic: Getting Logs for the WM  (Read 3141 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: February 25, 2018, 04:53:03 PM »
I got a call last week about a Cherry tree that was taken down and some Elm and Poplar also. I get calls a lot like this from home owners who have arborist take them down in in people's yards.  Most people don't want heavy equipment (bodcat, tractors) messing up their yards so my Log Rite ATV arch is always a hit with those folks. Anyways I took the arch out Friday and transported the logs to my trailer. This also gave me a chance to try out my new Portable Winch.  Up until now I have been using a hand crank winch in situations like this which worked, but also made for a long day.  The winch has a 50cc Honda engine and is rated to pull 2,200 on a straight line pull. Could easily double that with some snatch blocks.  The winch worked great and I got the logs loaded in no time. I am going back tomorrow to get the poplar and the elm. I made a video showing the winch and the days work. Also gave me a good reason to use my new drone. Thought I would share with you guys on here,
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Online firefighter ontheside
  • I like trees.
Re: Getting Logs for the WM
« Reply #1 on: February 25, 2018, 06:05:38 PM »
That works well.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #2 on: February 25, 2018, 06:15:55 PM »
Good vid!
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: February 25, 2018, 06:24:24 PM »
   I did not catch where you got the winch from, capacity or cost but I agree - I need one. Where did you get it? Make, model, cost, etc?
    As to the limbs/knots hanging on the trailer if that is a common problem you might put a roller (Pipe, post, cut off top, etc) cross ways under the front of the log then winch it up. That will give it extra height and reduce resistance and even allow you to move a bigger log. If you are using rollers to move one a long distance use 3 rollers with one in front, 1 in middle and one at the end. As the log rolls off the end move it to the front. We've moved heavy granite slabs long distances using a couple of 2X12 boards for track and 3 pieces of pipe and push with a long spud type bar.
   I hope that was an ivy vine not poison ivy BTW. I could not determine if it was a hairy beast from what I saw.
Offline loganworks2
« Reply #4 on: February 25, 2018, 06:52:01 PM »
Check them out www.portablewinch.com
  • I like trees.
« Reply #5 on: February 25, 2018, 06:52:38 PM »
I was thinking the same thing about the poison ivy.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Bruno of NH
« Reply #6 on: February 25, 2018, 07:34:55 PM »
Nathan
Would a steel roller added to the back of you trailer help in loading ?
In the 80's the lumber yard trucks in my area didn't dump they had a roller on the back and the driver turned it with a ratchet and the load rolled off on to the ground.
They went away by way of the insurance man :D
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #7 on: February 25, 2018, 07:59:05 PM »
I watched the video on YouTube before I read this thread. Great video!  I really like capstan wenches. They are very safe and effective.
1992 LT40HD
Offline 123maxbars
« Reply #8 on: February 25, 2018, 08:42:56 PM »
That was good old Ivy, but sometimes I get lucky and it doesn't effect me much,
I plan on getting a roller of some sorts for helping get the logs started on the trailer.
The winch runs around 1500$, it can straight line pull 2200 lbs, So far its been a good
tool to have, looking forward to taking it into the forest and using it to help pull my fetching arch,
outofthewoods
Youtube page
Out of the
« Reply #9 on: February 25, 2018, 09:25:36 PM »
That was good old Ivy, ...
Nathan,
   Not clear to me - was it ornamental ivy or poison ivy?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #10 on: February 26, 2018, 08:06:50 AM »
You will know by the time you take a bath tonight :D
Online DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #11 on: February 26, 2018, 11:02:09 AM »
The Logrite arch in combination with any kind of winch is a huge plus in recovering yard logs.    I've been using that method for quite a few years now.
New - 3 Wheeled Logrite Arch in General Board
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline Chop Shop
« Reply #12 on: February 26, 2018, 02:40:56 PM »
For that kinda money or less, you could have a Warn 8274.    Way faster pull.  Way stronger pull.   No gas, no pulling a start rope.
I regularly pull 24-36"x8-16' cedar logs on to my trailer with mine.
Cuz remember, time is monies!  ;)
Offline starmac
« Reply #13 on: February 26, 2018, 03:12:58 PM »
I have a couple of the warns, and they are very good and rebuildable too, but not near as versatile as a gas, chainsaw winch. Just different uses.
« Reply #14 on: February 26, 2018, 05:47:15 PM »
   I'm with Starmac on this one. I can easily see using a gas winch in the woods pulling from tree to tree till I get to a landing. With a trailer/equipment mounted electric winch you can't do that as easily. Plus it looks to me to be easier to refill a gas tank than recharge a battery.
Offline Wallys World
« Reply #15 on: February 26, 2018, 06:08:10 PM »
My trailer has a similar metal piece going across the deck. I carry a piece of roofing tin and let the log slide on that across the strip. Just lay it down and roll the log on it , chain up and pull away. It doesn't have to be too long, enough to go over both strips. Cheap, easy fix! I have a 4500 pound Superwinch on the front of the trailer.
Wood-Mizer LT28G25, Wood-Mizer EG10 Edger, Wallenstein Timber Talon log loader trailer, Wallenstein GX640 wood splitter, Wallenstein WP835 Fire Wood Processor, Kubota BX 22 TLB, JD 445, JD Gator, Home made arch, Stihl 024 Super, MS251, MS311, MS440 Magnum & 056
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #16 on: February 26, 2018, 06:45:39 PM »
I have gas and electric. Both have there place. I you using it a lot then gas is the way to go. Electric is hard on batterys.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline clintnelms
  • Woodmizer LT35HD
« Reply #17 on: February 26, 2018, 07:48:34 PM »
I didn't know you were on here. Love your videos. Watch them all the time. Keep up the good work!
Offline 123maxbars
« Reply #18 on: February 26, 2018, 09:17:09 PM »
Nathan,
It was poison,
outofthewoods
Youtube page
Out of the
Offline 123maxbars
« Reply #19 on: February 26, 2018, 09:21:50 PM »
the reason I went with the gas over the battery/trailer mounted was in the name it's self, It is portable, cant lug a battery powered one into the woods etc,  I have used it twice now and can't be without it,
Glad you guys liked the video, I really enjoy making them,
outofthewoods
Youtube page
Out of the
Wanted - small diamater low grade walnut logs and pallet logs ...
Started by Wes Lyon on Wanted
Last post August 12, 2006, 10:31:53 PM
by Wes Lyon
blue stain pine logs,aspen logs, Colorado
Started by logloper on Wanted
Last post February 23, 2010, 09:52:24 PM
by logloper
8 ft logs vs vs split logs for seasoning firewood
Started by Christopher7789 on Drying and Processing
Last post March 30, 2017, 10:45:58 PM
by GeneWengert-WoodDoc
Want some logs?
Started by Ianab on General Board
Last post July 09, 2017, 08:50:10 AM
by dgdrls
