Author Topic: Leaking oil tank in a 345 husqvarna  (Read 1334 times)
Offline Mako Hall
« on: March 02, 2018, 05:29:54 PM »
Hello everybody, I have a leaking oil tank in a 345 Husqvarna chainsaw. It seems to be leaking right
out of the bottom of the saw where the two sides of the tank attach to each other and I just can't find
any way to tighten it or anything. Any help would appreciated.
Offline Spike60
Re: Leaking oil tank in a 345 husqvarna
« Reply #1 on: March 05, 2018, 07:48:18 AM »
Not sure I understand the situation Mako. The 345 doesn't have a tank with 2 sides as on the metal cased saws like the 346/353. It has a molded plastic tank for the bar oil. Is there a chance the the handle was ever removed in the past? Occasionally someone gets the handle bolts mixed up. If the longer bolts from the side are used in the bottom, they will wear a hole in the case right into the oil tank.
But also, oil travels. Oil down there could be coming from higher up. There is also the possibility that the oil pick up line is no longer sealing as it goes through the thank, and may need to be replaced.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Offline Mako Hall
« Reply #2 on: March 06, 2018, 08:02:59 PM »
I am not really familiar with that saw. I just assumed that the tank had two sides. You know that little line or crack on the front of the saw it seems leaking right out of there. I did have a problem with the bolt from the handle puncturing the tank but I patched that with JB Weld and cut the bolt shorter and it does't leak there any more. Last time I used that saw the chain oil was getting on the fan and spraying oil everywhere.  You definitely know what you are talking about.
Offline dougand3
« Reply #3 on: March 07, 2018, 11:55:54 AM »
You could try JB Weld or plastic repair on the front seam. Search plastic repair methods. As far as oil hitting flywheel and slinging....Another crack beside flywheel? Maybe oil is dripping off front and finding the air stream into flywheel...but that seems a stretch.
This chassis has been whacked pretty good, I'd bet.
Husky: 372xt, 272xp, 61, 55 (x3) Stihl: 026, 011AVT Poulan: 315, 4218 (x3), 2375, 2150, 2055, 2000 (x3) Homelite XL
Offline mike_belben
  • Pulp Friction
« Reply #4 on: March 08, 2018, 02:40:03 PM »
the muffler loosened and the blowdown gas has melted a hole in top the oil tank.  I have a box full of the clamshell husky and jonsereds with bad cases.  Pull muffler, you cant miss it.
Revelation 3:20
Offline Mako Hall
« Reply #5 on: March 09, 2018, 12:47:18 PM »
Thanks, I will try that.
diesel tank leaking
Started by slider on General Board
Last post July 26, 2012, 02:01:26 PM
by beenthere
Husky 51 Gas Tank Vent Leaking
Started by kenskip1 on Chainsaws
Last post May 27, 2017, 08:17:11 PM
by kenskip1
leaking fuel tank on Husky 372
Started by WV_hillbilly on Chainsaws
Last post June 28, 2015, 11:23:31 PM
by WV_hillbilly
Need help with Husky 365 Leaking bar oil tank empty
Started by egraham on Chainsaws
Last post October 16, 2015, 12:52:58 PM
by Grandedog
