Tally-I/O
Author Topic: Log Rite Fetching Arch  (Read 1469 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: March 06, 2018, 01:23:54 PM »
I finally got to use my new Log Rite fetching arch yesterday. In this setting I used it to get logs up on on my trailer. I also used my portable winch as the power to move the arch. It worked pretty good and put the log up where I needed it to be. After I got the log on the trailer I pulled it straight with the winch to finish it off. Hope to use it in the woods soon. Lots of rain up here in TN.
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Log Rite Fetching Arch
« Reply #1 on: March 06, 2018, 02:23:57 PM »
I've seen so many times people winching a log onto a trailer and it gets hung on everything in it's path. The Logrite Arch was a cure for the problem......
......I was a witness.  :) Another good video.
I can see the rain clouds on the map right now, lots of water.
Offline Brad_bb
« Reply #2 on: March 06, 2018, 04:00:54 PM »
Jeez that looks like a long bar on your chainsaw?  I use a 25" for everything on a 661.
Instead of winching the arch up the trailer, try backing the arch using the 4 wheeler up the trailer.  At the end of this video you can see me do that a little.  I will also back up all the way on the trailer even when there's another log on there.  One tire of the arch will ride up, but that's ok.  Whatever it takes to get them on with the least work.
Offline 123maxbars
« Reply #3 on: March 06, 2018, 04:14:36 PM »
That is how I do it when I use my ATV arch,
I wanted to see if I could do it this way in case I was without my ATV arch.
I like the longer bar, keeps me from having to bend over so much and is a great workout also,
outofthewoods
Youtube page
Out of the
Offline sublime68charger
« Reply #4 on: March 07, 2018, 10:30:09 AM »
great video and thanks for sharing.
also really like your youtube channel!
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #5 on: March 07, 2018, 12:20:46 PM »
"So don't be heavy, no lighten up." Good lyric for a fetching arch video!
My fetching arch
Started by kelLOGg on Sawmills and Milling
Last post January 03, 2015, 04:57:13 PM
by kelLOGg
Logrite Fetching Arch
Started by thekitz on LogRite Tools and Rite Leg Co
Last post January 29, 2014, 12:40:59 PM
by Tam-i-am
Using my fetching arch with Fat Olde Elf
Last post June 24, 2013, 04:40:25 PM
by kelLOGg
Upgraded my Fetching arch
Started by sprucebunny on LogRite Tools and Rite Leg Co
Last post September 20, 2011, 12:04:59 PM
by Tam-i-am
