Author Topic: Stihl 44 carb sticking in choked position  (Read 331 times)
Offline Canadiana
  • I was new a while ago
« on: March 12, 2018, 08:21:23 PM »
After replacing the cylinder gasket on stihl 044, the choke valve on the carburetor sticks in the choked position. I pulled the starter til fuel came out the muffler :-[. Wasnt fun. I must have not attached some linkage or something properly when it was put back together. I have a part # 1128 120 0625 but I'm having trouble confirming it is a walbro and finding an appropriate drawing for it. Pictures are coming   ::) but slowly. Is the choke valve stem supposed to be interlocked with something else in choke linkage or just spring loaded?
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
Offline joe_indi
  • The older I get the more I learn
Re: Stihl 44 carb sticking in choked position
« Reply #1 on: March 12, 2018, 09:49:12 PM »
The few times it has occurred when I repair a 44 or 46 (aka 1128 series) is when the carb nuts were unevenly tightened or over tightened.
Try loosening them with the choke shutter stuck.
99% of the time it becomes unstuck.
Once this happens re-tighten the carb nuts. I use two fingers to tighten them not a fist
Offline Canadiana
« Reply #2 on: March 12, 2018, 10:01:17 PM »
Voila! Nice one Joe, you guessed it
New Stihl carb or Warblo carb?
Started by ihookem on Chainsaws
Last post April 24, 2015, 07:45:06 PM
by SawTroll
Stihl 011 AV - gas in the carb box
Started by chainsaw_louie on Chainsaws
Last post July 12, 2009, 01:00:12 PM
by chainsaw_louie
Stihl 036 carb problem
Started by limbwood on Chainsaws
Last post November 06, 2013, 01:02:38 AM
by joe_indi
stihl 025 replacement carb
Started by tbrickner on Chainsaws
Last post October 19, 2010, 09:51:25 PM
by tbrickner
