Author Topic: Chinese carbs  (Read 2177 times)
Offline Woodcutter_Mo
Chinese carbs
« on: March 17, 2018, 05:39:30 PM »
 Hello. Thought I'd share a tip when using one of the cheap Chinese carburetors. I rebuilt my old Stihl 024 last year. I replaced the piston/rings, hoses and resealed it because it was low on compression and the crank seals were starting to leak a very little bit. I also ended up replacing the carb with a cheap Chinese clone, which I bought to test if the old carb was still bad even after rebuilding.
The Chinese carb fixed the saw and has worked well until recently when it started running lean when hot. After compression tests showing still 165-170 psi and perfectly passing the vac/pressure tests, I opened up the Chinese carb and found some very small aluminum shavings from the manufacturing process which I figure may be my problem.
When buying one of these carbs (or any new carb for that matter), I suggest taking it appart and giving it a through cleaning before installing, which honestly I should have in the first place. Other than this problem, the carb has impressed me with how well it has worked for the price which I think was like $12.
Hopefully that is helpful to someone  ;)
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline moodnacreek
  • Sawin by the notches
Re: Chinese carbs
« Reply #1 on: March 17, 2018, 08:04:42 PM »
Thanks for this tip. I have a few of those carbs on hand and the ones I have tried where not very good. Because they were new I didn't take them apart.
Offline ljohnsaw
Re: Chinese carbs
« Reply #2 on: March 17, 2018, 08:52:31 PM »
I replaced a carb on a Kohler 16hp engine with a knock-off carb since the old one was a chunk of rust.  Worked for a while then was leaking fuel.  Opened it up and found the float was not set right (wouldn't cut off the fuel) and a dead, fully intact, bug (" long, 1/8" dia) in the bowl.  I'm pretty sure it didn't come through the needle valve! :-\
John Sawicky
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: Chinese carbs
« Reply #3 on: March 19, 2018, 05:14:22 PM »
When I saw this title I thought is was about rice
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Re: Chinese carbs
« Reply #4 on: March 19, 2018, 06:04:39 PM »
Thinking to your self "doesn't he know there's a "FOOD! FOOD! FOOD!" section ?!"   :D
 That's a good one!
Offline Mad Professor
Re: Chinese carbs
« Reply #5 on: March 19, 2018, 09:12:16 PM »
Maybe that how the emerald ash borer got here!
Offline Deere80
Re: Chinese carbs
« Reply #6 on: March 20, 2018, 12:00:50 PM »
I also have bought a few of them cheap carbs and it has been the roll of the dice on them.  One will be good and the next one you can not adjust to save your hiney.
Wood-Mizer LT35HD
Offline wild262
Re: Chinese carbs
« Reply #7 on: March 22, 2018, 11:04:27 AM »
       Can anyone share who the vendors are that they have had the best success getiing good aftermarket carbs?  Or is it a "hit and miss" with any of them.  I've had mostly bad luck with Zama's .  Put kits in them and still will not work.  Check valves I was told.  I build a lot of Husky 350s and 346 conversions. Will be starting on the 357/359 series with the Walbro 199 carb shortly.  Any help is appreciated.
Offline HolmenTree
Re: Chinese carbs
« Reply #8 on: March 22, 2018, 01:22:57 PM »
I never buy aftermarket only OEM.
Here's a OEM Husqvarna 346XP carb (Chinese Zama.)
Works perfect and seeing Stihl owns 100% of Zama I got good faith in them.
Re: Chinese carbs
« Reply #9 on: March 22, 2018, 03:02:24 PM »
I should specify, unbranded Chinese aftermarket clone carburetors.  ;)
 I bought this one primarily to test to see if the old but rebuilt oem carburetor was at fault before spending $95 at the dealer for a new OEM. I agree OEM is best when it comes to replacement saw parts, regardless of where they're manufactured.  ;)
Offline wild262
Re: Chinese carbs
« Reply #10 on: March 22, 2018, 09:14:44 PM »
        Well, I agree OEM is the best way to go.  But its been my understanding that the Zama's are all considered aftermarket since there all made in China regardless if there OEM or not. I can't really believe that a OEM Zama carb. would be made any better than non OEM, since there all made in China.  I knew that Stihl owns the company now.  Was just hoping that if someone recently bought some "good ones", I could buy some too from the same vendor, increasing my odds of getting good ones.   Is there a Stihl vendor there making them as well?  If so, than I can see where the quality would be better.  Is my thinking correct on this?
after market carbs ?
Started by scully on Chainsaws
Last post August 29, 2013, 08:44:00 PM
by bandmiller2
Chainsaw carbs
Started by blue_eyed_devil on Chainsaws
Last post September 25, 2003, 06:14:17 AM
by redpowerd
question
038 Magnum Carbs.
Started by rongavaldon on Chainsaws
Last post October 24, 2013, 06:48:45 AM
by Al_Smith
Comp carbs
Started by SasquatchMan on Chainsaws
Last post November 10, 2003, 04:15:44 AM
by Minnesota_boy
