Author Topic: comparisons  (Read 2859 times)
Online Bruno of NH
Re: comparisons
« Reply #20 on: April 19, 2018, 07:32:11 AM »
The frame on the Thomas is what sold me.
The trailer package is a little better than the EZ
I load with grapple and forks so I like the high bunks.
Don't like the clamps on the Thomas
I need to find some thing different
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Online thecfarm
Re: comparisons
« Reply #21 on: April 19, 2018, 09:00:53 AM »
Don't like the clamps? That is another reason I bought Thomas. The ease and the quickness of them. I don't think they changed the design.
Here's a picture of my frame. I got the No- Flex track. That is the piece of rectangle tubing,2"X 4" under the rail. I think I could pick the mill up at the cornor,shake it around and put it back down and it still would be level.
Online Bruno of NH
Re: comparisons
« Reply #22 on: April 19, 2018, 09:20:47 AM »
My Thomas has 2x6 frame under the track
Offline mroldstyle
Re: comparisons
« Reply #23 on: April 19, 2018, 05:48:04 PM »
So what does the EZ 40 have for band engagement? There website doesn't say, a video I watched looked like a lever to either tighten belt or move the  engine?
Online thecfarm
Re: comparisons
« Reply #24 on: April 19, 2018, 07:44:52 PM »
Bruno,I went and checked,it's 4 inches. You have the wide head,that might why yours is 6 inches.
Offline Skipper11A
Re: comparisons
« Reply #25 on: April 20, 2018, 12:00:21 AM »
The EZ 40 has one lever that slides the engine on a shaft to tension two  drive belts, which drives the drive wheel.  Also attached to this lever are linkages that open the throttle and open the blade lube.  So with one move of the lever, the drive belts are tensioned, the throttle is opened, and the blade lube is opened. And when the lever is moved down, everything is shut off.
You mentioned EZ Boardwalk's website and I must point out that these folks are Mennonites and their religious beliefs preclude them being on the internet.  A neighbor is hosting their website and it lacks fancy sales techniques that we are used to.
Offline mad murdock
Re: comparisons
« Reply #26 on: April 21, 2018, 09:33:35 AM »
mroldstyle-as drgrls asked, have you looked at swing blade circle mills? They are fast and true, no moving of the log needed once set up to begin milling. Quartersaw a log without ever touching the log. Mill it down to the nubbins removing only boards and firewood (slabs) till you get to the bottom of the log. Built in edger on a swingblade and cheap to operate as blades last and last and resharpen on the mill in a minute or 2. My Turbosawmill is easy to move and as fast as an LT40 class of mill for a lot less$$. With the Alaskan cradle option I have I can slab wide also. Good luck on your search, and welcome to the Forestry Forum!!
Tree shear comparisons
Started by chubby on FARMA
Last post August 19, 2019, 11:07:42 PM
by Southside
hello, and looking for saw comparisons, 441, 461, similar saws any brand
Started by shootingarts on Chainsaws
Last post November 06, 2013, 08:42:43 PM
by shootingarts
New Saw Comparisons: Husqvarna 543XP to Echo CS 361P to Stihl MS 241 CM
Started by kantuckid on Chainsaws
Last post January 13, 2016, 02:39:06 PM
by kantuckid
