Author Topic: Diesel blade lube and rubber drive belts?  (Read 980 times)
Offline Jhoff
« on: April 17, 2018, 03:05:52 PM »
I would like to switch from water drip blade lube to a diesel wick lube. My only concern is I am runing a rubber and Kevlar drive and idler belts on my wheels. Will the diesel swell them and become a problem? If I switch the belts to polyurethane, will this hold up to diesel? I like the cooks set up but they use metal drive wheels. Let me know what you guys think. Thanks.
Offline slider
  • sawyer,trucker,tree service
Re: Diesel blade lube and rubber drive belts?
« Reply #1 on: April 17, 2018, 04:08:05 PM »
Been using it for years with the belts from woodmizer,i think they are gates.
al glenn
Offline ladylake
« Reply #2 on: April 17, 2018, 04:56:12 PM »
 I run diesel in the winter and water in the summer with no trouble.  Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Online thecfarm
« Reply #3 on: April 17, 2018, 09:30:55 PM »
I have a Thomas mill. Been doing it since day one. I have no idea what I have for belts. It's only a drip every few seconds,if that. But I am not doing furniture wood. Just out buildings. I don't know if the diesel would affect the stain or not. I also put some bar and chain oil in the diesel too. That's what he told me, half and half.
Offline bandmiller2
« Reply #4 on: April 18, 2018, 06:54:16 AM »
Jhoff, you have the right idea when you mentioned wick for thats the key to applying petro based lubes. With a wick you not only apply lube sparingly but also physically clean the band. I have quit using diesel myself and now use drained hydraulic oil or ATF just don't use drained engine oil as it contains products of combustion which can be harmful. Applied sparingly with a wick absolutely no harm to belts. Frank C.
Offline Jhoff
« Reply #5 on: April 18, 2018, 07:10:45 AM »
Thank you guys for the help on this. It looks like I will be switching over.
Offline PAmizerman
« Reply #6 on: April 18, 2018, 08:37:58 PM »
Jhoff what are you sawing that is giving you enough trouble that makes you want to use diesel?
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline Jhoff
« Reply #7 on: April 20, 2018, 10:47:32 AM »
Nothing. Just rebuilding my saw and want to get rid of the large water tank for a 1 gal tank.  I am told diesel  will last much longer and saves on the roller guide bearings.
WM drive belts on diesel engines
Started by barbender on Sawmills and Milling
Last post November 02, 2014, 08:36:14 AM
by petefrom bearswamp
Blade Lube.....Diesel????
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 08, 2011, 07:39:41 AM
by bandmiller2
Useing diesel as blade lube
Started by HD on Sawmills and Milling
Last post December 22, 2010, 08:55:20 AM
by Magicman
Diesel Fuel for blade lube?
Started by epiphoneprs on Sawmills and Milling
Last post September 02, 2009, 06:52:04 AM
by Chico
