Author Topic: ID? Several of these in woods behind my house. Check out the leaf projections...  (Read 2120 times)
Offline Don P
    • Calculator Index
No doubt about it. I try to pound a little more latin into my pea each year. Pretty sure I'll just end up with a split pea though :D. The reason I was asking about wahoo is we had a mason some years ago asking if I knew of a tree called a wahoo, the closest I could come up with from the description was winged elm, well obviously that ain't it, what is the other wahoo?
Offline caveman
  • In the land of the blind the one eyed man is king
Most winged elms have "alata" wings or corky projections on the stems and twigs.  The only wahoo that I'm familiar with is a pelagic denizen of the deep.
Caveman
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Pelagic denizen.
I ain't the only sesquipedalian :D
Online LeeB
Are you required to register with the local law enforcement because of that?  :D
Offline WDH
  • Forester
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
WDH, thanks for the confirmation and vocabulary lesson!
Would have replied sooner, but was laughing too hard at this, and got distracted relaying it to my wife.  ;D
Offline caveman
Danny, I told my mother what you implied that I was and she said that as long as you did not call me a loquacious sesquipedalian that it was okay.
Caveman
Offline WDH
  • Forester
No, you are not overtly loquacious.
Climate Projections for Michigan Tree Species
Started by Ron Scott on Forest Education
Last post November 19, 2015, 10:29:41 AM
by mesquite buckeye
Before Pulling Your Mill....Check and Re-Check!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 09, 2018, 01:44:17 AM
by Ianab
question
Heating a hoop house/green house.
Started by pinebugsrus on Firewood and Wood Heating
Last post June 03, 2012, 08:21:44 PM
by pinebugsrus
7 leaf ash value
Started by shelbycharger400 on Forestry and Logging
Last post November 16, 2011, 07:21:52 PM
by WDH
