Author Topic: Kiln insulation  (Read 1568 times)
Offline Bnewman712
Kiln insulation
« on: May 25, 2018, 06:47:45 AM »
Does anyone know if putting celotex thermal polyisocyanurate board on the walls is good? Itís foul faced so seems like it may work even better to reflect the heat in????
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Kiln insulation
« Reply #1 on: May 25, 2018, 07:36:30 AM »
I used it on mine.  Covered it with a vapor barrier then covered that with a layer of 1/2" treated plywood.  If you don't cover it with plywood, you will  knock holes in it or tear it up.
Offline Bnewman712
Re: Kiln insulation
« Reply #2 on: May 25, 2018, 08:03:48 AM »
I will cover it most likely but just thought it may work better not
Offline WDH
  • Forester
Re: Kiln insulation
« Reply #3 on: May 25, 2018, 07:06:15 PM »
You will definitely tear it.
Offline Bnewman712
Re: Kiln insulation
« Reply #4 on: May 25, 2018, 08:46:26 PM »
Ok btw how do you like the kd150
Offline GeneWengert-WoodDoc
Re: Kiln insulation
« Reply #5 on: May 26, 2018, 07:49:20 AM »
The foil does not help in a well insulated wall.  It does make a good vapor barrier, but best to also use plastic.
Offline WDH
  • Forester
Re: Kiln insulation
« Reply #6 on: May 26, 2018, 07:52:30 PM »
I have the Nyle version, the L53.  It is the same as the KD150.  Nyle makes both, they are one and the same.  It is a little wood drying beast, for sure.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Kiln insulation
« Reply #7 on: May 26, 2018, 11:40:27 PM »
I have one also, and it is a good machine.
HobbyHardwoodAlabama.com
Offline Bnewman712
Re: Kiln insulation
« Reply #8 on: May 27, 2018, 03:28:26 PM »
Cool what does setting pitch mean??
Offline WDH
  • Forester
Re: Kiln insulation
« Reply #9 on: May 27, 2018, 08:03:55 PM »
Running the temp in the kiln up to 150 degrees or so to make the sticky pitch set and get solid so that it does not ooze pitch on your customers projects.  Just make sure that you turn the compressor off before you set the dry bulb temp at 150 degrees or you will trip the compressor.  Don't ask me how I know this.......... :)
Offline Bnewman712
Re: Kiln insulation
« Reply #10 on: May 27, 2018, 09:07:32 PM »
Haha so when itís dry 8-10% I set to 150 to do that for how long? And does not matter what type of wood? And by what do you mean ozz out?
Offline WDH
  • Forester
Re: Kiln insulation
« Reply #11 on: May 28, 2018, 07:55:03 AM »
Yes, at the end of the drying cycle, turn off the compressor and set the dry bulb temp at 150 degrees.  When the chamber gets to 150 degrees, hold that temp for 24 hours.  This will set the pitch in softwoods and sterilize hardwoods to kill any beetles, larvae, or viable eggs in the wood.
You don't want sticky boards in resinous wood like pine.  You also do not want insects in the wood.
Re: Kiln insulation
« Reply #12 on: May 28, 2018, 08:29:49 AM »
The longer you hold the 150 F, the more sap, that would be sticky and/or move, you will evaporate.  I would suggest that 2 days will do a fairly good job.  Note that at this temperature, moisture will evaporate, so try to keep the kiln sealed up as best you can to stop moisture loss.  The greater the moisture loss, the more warp, the more brittleness when machining, and the harder to nail and saw.
Offline Bruno of NH
Re: Kiln insulation
« Reply #13 on: May 28, 2018, 04:25:40 PM »
Do you need the vaper barrier ?
If you tape the joints on the foil face insulation with vaper tape or foil tape?
Bruno
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline WDH
  • Forester
Re: Kiln insulation
« Reply #14 on: May 28, 2018, 04:43:20 PM »
I would say yes.  Just a cheap way to guarantee a very good vapor barrier.
Offline Bruno of NH
Re: Kiln insulation
« Reply #15 on: May 29, 2018, 07:41:08 PM »
I'm just taking this all in.
I'm going to have a kiln at some point
Insulation for New Kiln
Started by pine on Drying and Processing
Last post January 19, 2017, 10:34:52 PM
by Darrel
Kiln insulation?
Started by WoodChucker on Drying and Processing
Last post May 15, 2004, 10:55:03 PM
by WoodChucker
Kiln Insulation?
Last post April 21, 2004, 10:41:32 AM
by Ga_Boy
SOLAR KILN INSULATION
Started by rs1626 on Drying and Processing
Last post April 23, 2005, 01:03:39 PM
by Larry
