Author Topic: Vacutherm iDry input  (Read 19071 times)
Offline PA_Walnut
Re: Vacutherm iDry input
« Reply #300 on: April 17, 2019, 07:28:20 AM »
PA I love your style!  I so wanted to do that on several occasions!!!!!!!!!
It will set your soul free! ;D:D
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline rjwoelk
    • countrysidefirewood
« Reply #301 on: April 21, 2019, 10:49:54 PM »
Can you dry up to 6x6x8ft
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #302 on: April 21, 2019, 11:50:54 PM »
I would dry it. I would like to see how long it takes.
Offline rjwoelk
« Reply #303 on: April 21, 2019, 11:55:58 PM »
According to DH kilns it falls into the same category as pine.
So what time frame would it take to dry, and at what cost.
Offline K-Guy
    • http://www.nyle.com/
« Reply #304 on: April 22, 2019, 08:07:32 AM »
Hi
For timbers that thick, the drying is very slow. It would take months in the kiln. It would better to air dry it down to about 20% and then put it in the kiln for finishing and sterilization.
Nyle Kiln Sales & Service
Offline Stephen1
    • muskoka Sawmill
« Reply #305 on: April 29, 2019, 08:32:42 PM »
Syrup season is over and cleaned up.I  am going to move lumber to my klin from the bush. I will bring some timbers down and put them in when I have room, and see how long they take.
I am looking at metal baskets to fill with firewood. i think there is a market for kiln dried firewood.
Who uses thier kilns for firewood?
Offline Stephen1
    • muskoka Sawmill
« Reply #306 on: May 03, 2019, 06:38:18 AM »
I had a large amount of ants and dirt in the last load of 34" walnut slabs, so much so, tha the drain hole in the rear of kiln became clogged. I opened the kiln after 9 days to check the load and a huge amount of water was draining out the front door, and out of the kiln. Since then I have re-plumbed the drain on the kiln with a pan and a pump.
In the mean time when I pulled out the load after a total of 12 days I found a small amount of a white fungi on the walnut around 1 of the cavities that had dirt in it. I have brushed it off and vacuumed it off but a small amount remains.
I'd like to wipe it off with some bleach but I am afraid the bleach will stain the walnut.
Any ideas?
Offline Just Right
    • JustRightSawing
« Reply #307 on: May 04, 2019, 07:50:13 PM »
The day of off loading and setting.  Got it fired up this week and a load has been in there for 4 days now.  At full temp around 160 ish.  Can't wait to see the progress.
Stephen,  maybe some of that house wash stuff for the fungus among your walnut?
If you are enjoying what you are doing,  is it still work?
Offline Stephen1
    • muskoka Sawmill
« Reply #308 on: May 05, 2019, 08:39:03 AM »
I'll give that a try.
I will also see if extra strength vinegar will work
Offline Just Right
    • JustRightSawing
« Reply #309 on: May 05, 2019, 10:04:28 AM »
Let me know how that turns out.  Going to open my kiln today to check progress.
Please welcome our newest sponsor! iDRY Vaccum kilns
Last post December 02, 2018, 08:04:14 AM
by fishpharmer
question
Need Your Input
Started by jwhuntman on Forestry and Logging
Last post November 16, 2011, 10:27:56 PM
by jwhuntman
Need input
Started by Merles Okie on Sawmills and Milling
Last post October 20, 2012, 08:11:33 PM
by 1woodguy
Looking for some input
Started by summerboy1958 on Chainsaws
Last post June 26, 2015, 09:12:01 PM
by Ianab
