Council Tool
Author Topic: Stihl 880 failed to start  (Read 2972 times)
Offline Busysawyer
« on: August 31, 2018, 10:57:31 AM »
Its pretty obvious why it wouldn't start. I ran a few tanks through it yesterday with no issues.  Went to use the saw this morning and pulled it a few times. Normally the saw sputters first or second pull and runs in one or two more pulls. I pulled it 5 or 6 times with not a hint of starting and immediately thought something's wrong.  I had just topped off the fuel and bad oil so went to the first logical place and pulled the plug.  What I found was the plug was missing the ground electrode.  I've never seen this before.  My concern at this point is the piece that broke off has trashed the cylinder and or piston. The dealer wants to try to fish the broken piece out with a magnet and throw a new plug in it. Should I push for a cylinder inspection?  I think they should fix the cylinder and piston if there is any damage. Saw is under warranty and I feel that a plug breaking off is most definitely manufacturing defect and should be warranted.
Offline ladylake
Re: Stihl 880 failed to start
« Reply #1 on: August 31, 2018, 11:35:02 AM »
 Under warranty, for sure the jug should be pulled and piston and cylinder inspected. Steve
Timberking B20 12000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Dino setter Volvo MCT125c skid loader
Online sawguy21
« Reply #2 on: August 31, 2018, 11:37:52 AM »
X2 Stihl may argue that is the plug manufacturer's problem but they are the ones that need to pursue that if it is the factory installed one.
Offline ehp
  • logger/chainsaw hack
« Reply #3 on: August 31, 2018, 05:30:00 PM »
you would be surprised how often this happens , sometimes you get lucky but most times nope . I would pull the cylinder off cause good chance sparkplug piece will be stuck in the roof of the cylinder or the piston . Also the piece could of went out the ext. port but most times the piston catches the piece going into the port and ruins the ext. top side of piston and cylinder
Offline Busysawyer
« Reply #4 on: August 31, 2018, 06:22:30 PM »
It is the factory installed plug. Saw is maybe 8 months old. I bought three professional level saws and a industrial power washer from these guys this year. If they give me a hard time about taking care of this the right way I'm going to flip. You guys have confirmed my thoughts and worries.  I'm going to bring the saw in tommorow and see what happens.  Thanks
Online Skeans1
« Reply #5 on: August 31, 2018, 07:42:26 PM »
Good luck with the warranty most professional stuff is 3 months just the name of the game.
Offline Busysawyer
« Reply #6 on: August 31, 2018, 07:56:42 PM »
When I bought the saw I told them exactly what I was doing with it and asked about the warranty.  The dealer didn't know so he put me in touch with their stihl rep. I told him exactly what i was using the saw for and he told me if I bought the stihl oil it would be covered for one year. I've had issues with this saw since new. I called the dealer about an hour after bringing it home with concerns about the way it was running.  I was told to run at least 10 tanks if fuel through it and see if it cleaned up. I did as instructed and it never ran better. I have talked to the dealer a few times since and they said they would need the saw for a week. I told them I use it a few times a week and couldn't be without it for that long at the moment. They said no problem just bring it in when you have a slow week.
Offline Busysawyer
« Reply #7 on: August 31, 2018, 08:04:10 PM »
As far as warranty was concerned, I was told if it is sold to a company like a tree service or full time logger it was a three month warranty. Like I stated before I told them exactly what I was doing with it. My concern was the warranty covering the saw if used on an Alaskan mill. They said they were selling me the saw as a homeowner purchase  and would have the full year if I bought the oil. If they dont stand behind what they told me I'm not going to be happy. I've always ran husky saws without an issue. My 455 is close to 15 years old and I have never replaced a single part. I bought 3 new stihl pro saws this year and so far 2 have needed parts within the first month and now this.
Offline Busysawyer
« Reply #8 on: September 01, 2018, 09:55:10 AM »
Well I brought the saw in today.  I've only been doing business with these guys for about 8 months and they have been great to work with. The reason I started buying from this place is they have a good reputation around town and are willing to work with customers on pricing. Long story short, most definitely covered under warranty. They are going to pull the jug and let me take a look. If there are any scratches or I just dont like what I see they are going to get me a new saw for free. They also said if the piston and cylinder look good and they still can't get it running to my satisfaction they will get me a new saw. They said they are a high volume stihl dealer and have never had an issue with stihl honoring a warranty claim.  They were very apologetic about the issues I've had with this saw and assured me they would do whatever it took to make sure I was happy with anything I buy from them.
Offline homestead090
    • My Website
« Reply #9 on: September 01, 2018, 10:32:31 AM »
Glad it worked out for you. I'm doing some milling with an 090, which works great, but curious about the 880. My saw really does well, I mainly cut big stuff, 3 - 4 diameter. Using a Granberg mill and milling chain. Not sure if you can compare the two saws, but I'd like to know your experience. I realize you have had problems with your saw.
Furniture maker and wood collector.
Offline HolmenTree
« Reply #10 on: September 01, 2018, 10:54:37 AM »
You can't replace 090 engine displacement with a smaller displacement saw.
I milled with my 1994 090AV for over 20 years and even tried a well broke in 880 on the mill. The 137cc 090 outclasses them all if milling big timber.
Offline HolmenTree
« Reply #11 on: September 01, 2018, 10:59:04 AM »
But having said all that I never got to try a 106cc 090 Gear drive. I heard stories of legends with millers in the California redwood country running 8 foot Alaskans with 090Gears running 137cc P/C.
Doesn't get any better then that :D
Offline barbender
« Reply #12 on: September 01, 2018, 12:56:18 PM »
Busy, I had an NGK factory installed plug come apart just like that on my Jonsered 2171. It was cutting, and all of the sudden it started rattling really bad. I shut it off as quick as I could. I pulled the cylinder, and my piston and the head were hammered badly. I could've maybe saved the cylinder, the piston was destroyed. The electrode I found in the bottom end, it hadn't caused any issues there. Seems to be more of these plugs doing this👎 Was yours an NGK?
Offline HolmenTree
« Reply #13 on: September 01, 2018, 04:33:15 PM »
Yup NGK, from what I see in the 3rd pic.
Offline Busysawyer
« Reply #14 on: September 01, 2018, 06:43:14 PM »
Homestead, I really have nothing to compare it to as far as milling goes.  Recently I did get to see a proper running stock 880 bucking some large logs. It confirmed my thoughts on mine being a dud. Mine has been doggy and un responsive since day one.
And yes guys it's the factory installed NGK spark plug.  Considering asking the dealer if they could replace the plugs in my 441 and 201 if they have NGK plugs.
Online lxskllr
  • dummy with saw
« Reply #15 on: September 01, 2018, 06:56:24 PM »
Is there something inherent in saws that would make that happen(high rpm?)? Never seen it before in my life running autos, mowers, and other low revving engines. A data point of two isn't that great, but if this could be an NGK issue, I'd probably replace my plug. I use the saw little enough the warranty could be gone if the plug fell apart.
Online Skeans1
« Reply #16 on: September 01, 2018, 07:02:08 PM »
We use to see it on the 250Rs when there was detention also with any plug we tried in them.
Offline barbender
« Reply #17 on: September 01, 2018, 07:56:59 PM »
My Mercury 40 hp 2 stroke outboard uses plugs that have no attached electrode. Which is how my saw was running and battered itself after the electrode fell off.
Offline Busysawyer
« Reply #18 on: September 01, 2018, 09:32:01 PM »
Barbender,  that is exactly what the mechanic told me today.  He said a lot of times if it breaks while running the plug will arc to the case and stay running. As you have experienced that will likely trash everything.  He said on occasion you might get lucky and have the piece blow out the exhaust port and get stuck in the muffler.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #19 on: September 01, 2018, 11:34:05 PM »
Makes me wonder if the saws poor performance history was somehow related to some original defect in the plug before it finally failed, or if the poor performance of the saw caused the plug to fail.
Either way, it should be the dealers problem, not yours.  Sounds like they are handling it as they should.
Ive had cracked insulators in my Stihls, and even badly eroded electrodes after too long between plug changes, but thankfully, Ive not had the electrode get swallowed.
HobbyHardwoodAlabama.com
Stihl 031 won't start.
Started by ahiggins1 on Chainsaws
Last post October 24, 2009, 11:55:55 PM
by ahiggins1
Stihl MS 660 not start when hot
Started by otherguy on Chainsaws
Last post June 20, 2017, 07:25:43 AM
by CTYank
Stihl BG 86 won't start
Started by JohnG28 on Chainsaws
Last post March 27, 2013, 07:13:54 PM
by JohnG28
Stihl 018 Will not start
Started by spike47 on Chainsaws
Last post March 18, 2014, 10:28:15 AM
by spike47
