Author Topic: New tool for the sawmill  (Read 1063 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: September 29, 2018, 01:27:50 PM »
I sold my Bobcat last month that I used to move logs and load my kiln. I never liked the Bobcat that much, I spent 12 years in a Police Car which gave me some slight back trouble when I left to run the sawmill full time. The  awkward position I had to get into to climb into the Bobcat seat always seemed to aggravate it. I had a Kubota tractor when I first got my sawmill but the loader capacity wasn't up to par. In the last few years I have watched tractors come a long way in the amount of weight they can lift. After shopping around for the last month I went with a new Mahindra. The tractor is 50hp and with the loader and wheel ballast comes in at 8k on total weight. The loader can lift 2800lbs to full height, though I usually just lifts logs up a few inches off the ground to place in from of the LT35.  Me and my wife also bought a farm yesterday so this tractor will perform double duty for farm chores etc.  I made a short video showing the delivery and specs. Now I have to move over 100 logs and my kiln, that will be the hard part  ;D
Sawyer/Woodworker/Timber Harvester
W/M LT35HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline Bruno of NH
Re: New tool for the sawmill
« Reply #1 on: September 29, 2018, 01:34:18 PM »
Max
I have the same tractor and I like it a lot.
I move some big logs around with it.
Mine is a cab model
Mahindra makes a heavy tractor and you won't have any issue with it revgening on you.
Bruno
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline ljohnsaw
« Reply #2 on: September 29, 2018, 02:25:57 PM »
Very nice!  Are you planning on armor plating the bottom if you go into the woods a lot?  When I'm done building, I'm thinking about getting a tractor if I can sell my SkyTrak.  Funny how excited you are about 2,800 pound lifting force.
I'm spoiled with my old SkyTrak that lifts 9,000 pounds.  And I find at times that is not enough! :o  When I pick up a little stick (14-16" x 16'), its like nothing.  It gets exciting when I have a 30" x 28' log and I extend the boom - I can feel the rear raise up a little.
John Sawicky
Offline thecfarm
« Reply #3 on: September 29, 2018, 06:23:42 PM »
Looks good.
Not to say anything about under armor. I cut on my land. Cut the limbs short,I try for 2 feet,if I am leaving them and plan my roads. I stop and move brush out of my trails. I cut the small trees out of my trails. Yes,it takes time,but when getting all the money,I can take the time.
Offline OffGrid973
  • Off Grid
« Reply #4 on: September 29, 2018, 07:52:51 PM »
I am beyond jealous, this is like my ultimate dream, a farm and new tractor.
Coming out a little hot during the drop off, I bet you loved that 2 seconds, ha ha.
Only watched 2 min, grabbed a beverage and going in for the rest now. Also looking forward to the series on the farm, hopefully they let you post Into The Farm videos on the sawmill forum, I vote yes if it matters.
Your Fellow Woodworker,
- Off Grid
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: September 29, 2018, 08:17:57 PM »
Bought a Farm?  That is exciting!
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #6 on: September 29, 2018, 08:36:06 PM »
Congratulations on the new tractor and new farm!  Be safe with that tractor!  Wear that seat belt!  I know it is inconvenient but so is having the grapes mashed out of you!  Loader work especially in a log yard can present tip over hazards.  The seat belt and ROPS are meant to work together.
I was loading firewood onto a truck last week using the FEL on a similar sized tractor.  With a full bucket I backed over a small pile of firewood with the right tire.  If I had not lowered the bucket quickly it might have have tipped over.  I've been running tractors up to 90 hp for 40 years and it was as close as I've ever come to turning one over.  And yes I wear a seat belt even in the cab tractor and rubber tire loader.
Be safe and enjoy!
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline samandothers
« Reply #7 on: September 29, 2018, 10:07:30 PM »
Congratulations on the new tool!  Nice looking ride.  Hope the gears work well for you.  I did notice the guy hitting the bucket during his dismount.  If you get a grapple it will be interesting to see how the close/ grip control works with the separate lever next to the seat.
I too look forward to the farm videos.  Does the farm have a home you plan to relocate to?  Glad you did not buy the farm in the alternate meaning.  :o
Offline Southside
« Reply #8 on: September 29, 2018, 11:56:14 PM »
Congratulations. What are your plans for the farming side of things?
Offline slider
  • sawyer,trucker,tree service
« Reply #9 on: September 30, 2018, 08:03:06 AM »
Times 2 on the seat belt. I got the bright idea of buckling the seat belt behind me to save time,well i can tell you , it's hard to stay in the seat when you are over on your nose.
al glenn
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #10 on: September 30, 2018, 08:19:38 AM »
Nice tractor, nice farm.  Congratulations.
HobbyHardwoodAlabama.com
Offline brianb88
  • Still thinking
« Reply #11 on: September 30, 2018, 11:54:00 AM »
Congrats on the farm and the tractor.
Measure twice, cut once
Offline 123maxbars
« Reply #12 on: September 30, 2018, 01:30:15 PM »
Not sure yet, the farm has an organic garden already in place and pasture/water for animals. i might get back into beef part time if things go as planned,
outofthewoods
Youtube page
Out of the
Offline 123maxbars
« Reply #13 on: September 30, 2018, 01:31:03 PM »
Yes it has a house that was built about 20 years ago,
outofthewoods
Youtube page
Out of the
Offline 123maxbars
« Reply #14 on: September 30, 2018, 01:32:50 PM »
Probably not on the bottom, I have nothing but pasture and this will stay at the farm to move logs etc,
And my excitement also steams from paying cash for this tractor, a years worth of walnut slabs have made me a happy farmer,  8)
outofthewoods
Youtube page
Out of the
Online Sixacresand
  • John and Nancy
« Reply #15 on: September 30, 2018, 04:16:13 PM »
Good deal on getting a tractor and a farm.  Glad you are able to get both at the same time.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #16 on: October 01, 2018, 11:15:52 AM »
Congratulations on the farm and the tractor.  If it's like Bruno's i'm jealous.  8)
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Newest sawmill tool.
Started by starmac on Sawmills and Milling
Last post August 30, 2015, 08:59:38 AM
by drobertson
Uncle Chick's old circle mill w/pictures - (was - Tool for old sawmill?)
Started by Bibbyman on Sawmills and Milling
Last post April 19, 2007, 08:45:57 PM
by Bibbyman
Tractor 3pt Multi-tool - And Another Log Handling Tool Added
Started by tcsmpsi on General Board
Last post February 08, 2007, 07:18:52 PM
by SPIKER
New [s]Toy[/s] tool?
Started by hackberry jake on Sawmills and Milling
Last post October 20, 2012, 10:58:30 PM
by Okrafarmer
