Author Topic: Husqvarna 365 leaking fuel when full  (Read 382 times)
Offline straincm
« on: October 14, 2018, 03:32:59 PM »
I inherited a Husqvarna 365. It leaks fuel when full and maybe greater than half full. I have tried taking the cover and air filter off, exposing the fuel line and mover th saw around. Fuel doesnít appear to be coming from around the fuel line. Any ideas?  Thanks
Offline skooter
Re: Husqvarna 365 leaking fuel when full
« Reply #1 on: October 14, 2018, 05:44:59 PM »
check the gas tank vent the vent just pushes in it will be right side of saw below the carbrutor compartment . if that vent is not there it will leak fuel when full. hope this helps.
             scott
Offline straincm
« Reply #2 on: October 16, 2018, 07:46:50 AM »
Took more covers off, it is leaking where the fuel line goes into the tank. Time to replace the fuel line. I checked the vent and it is in place and not leaking there.
Thanks.
husqvarna leaking fuel
Started by first shirt on Chainsaws
Last post March 03, 2009, 10:06:26 AM
by Etced
Husqvarna 357 XP leaking bar oil
Started by thutch85 on Chainsaws
Last post March 23, 2017, 07:03:07 AM
by backpacker
Leaking Bar Oil/Husqvarna
Started by RCrosby on Chainsaws
Last post May 23, 2012, 10:41:31 PM
by HolmenTree
Leaking oil tank in a 345 husqvarna
Started by Mako Hall on Chainsaws
Last post March 09, 2018, 12:47:18 PM
by Mako Hall
