Author Topic: Husky Rancher 50 restoration/rebuild?  (Read 307 times)
Offline Phil_Oz
  • G'Day from Oz
« on: December 14, 2018, 05:28:24 PM »
Hi All,
New member from Oz here. I live about 100Km from Sydney. I use my saws mostly for firewood, and a bit of yard work.
Here, you are usually either a Stihl, or a Husqvarna man. I have both. (Stihl MS291, Stihl MS170, Husqvarna Rancher 50 (~86 model).
The Husky Rancher 50 I have had well over 30 years, 3 bars, uncounted chains, and that saw kept us in firewood and warm for many winter seasons.
She is old, hard to start, and has basically been retired. I would like to rebuild/restore the old girl. She has been such a good saw, I wouldn't dream of getting rid of her. I would like to rebuild her, and give her pride of place in the garage. Retirement might even let me restore some more saws as a hobby.
So, where to start? Are workshop manuals available? I've read some threads here re rebuilds and parts, and viewed some YouTube videos, but here seems to be a great storehouse of knowledge.
(I would like to put a big bore kit in the old girl - has anyone done that for this model? and do you have any suggestions for rebuild kits - ie suppliers - OEM parts are very expensive here, so I am looking at (probably) aftermarket parts sourced on-line).
Offline Phil_Oz
  • G'Day from Oz
Re: Husky Rancher 50 restoration/rebuild?
« Reply #1 on: December 14, 2018, 09:48:56 PM »
OK did some further research (The Lord helps those who help themselves!).
Found a couple of free manuals in .pdf.
The 50, 50 special, 51 and 55 all have a stroke of 32mm.
My 50 has a bore of 44mm.
The most common aftermarket kit has a bore of 46mm - which would result in ~55cc displacement.
(Of interest on one e-bay kit providers page is a note;
Note Please:
PLS confirm the crankcase opening for the cylinder is 50MM,
rather than 48MM (older 50's crankcase plate is smaller).
That is interesting as it suggests that there are 2 different series of bottom ends - can anyone expand on that?
In another thread, someone said they had had good luck with a supplier out of HK - and there is one on e-bay who seems to have a more comprehensive kit - and with good ebay feedback.
So that is what I'm leaning towards, the HK supplier, and getting the 46mm bore kit - (My Rancher 50 is set to become a 55 it would seem).
Offline dougand3
« Reply #2 on: December 14, 2018, 10:49:21 PM »
The 46mm is 53cc.
They mean that the impulse hole in the 46 cyl won't communicate with the crankcase in a Husky 50. The hole sits on metal instead of open to crankcase = no impulse. Fix is to elongate cyl impulse hole. Well, you could grind out the crankcase top but more trouble and may get slivers in big rod bearing.
Husky: 372xt, 272xp, 61, 55 (x3) Stihl: 026, 011AVT Poulan: 315, 4218 (x3), 2375, 2150, 2055, 2000 (x3) Homelite XL
Offline Phil_Oz
  • G'Day from Oz
« Reply #3 on: December 22, 2018, 06:10:22 PM »
I'm starting to see tea connection between some of the YouTube videos I've been watching, and some of you regular senior statesmen type posters on here.
Found this one -'In Praise of the Husky 50s'?
help with old Husky 61 rancher. Rebuild?
Started by stoneaxe on Chainsaws
Last post December 14, 2018, 05:40:27 PM
by Phil_Oz
Stihl 038 Magnum restoration...continued. Carb rebuild and crank seals.
Started by Andy171361 on Chainsaws
Last post December 08, 2014, 07:15:57 PM
by HolmenTree
Husky 55 rancher
Started by bandmiller2 on Chainsaws
Last post January 31, 2013, 08:34:12 PM
by bandmiller2
Husky Rancher 55
Started by kenskip1 on Chainsaws
Last post March 16, 2004, 05:58:26 PM
by kenskip1
