Author Topic: Tandem axle bearing Valmet 646  (Read 824 times)
Offline leeroyjd
« on: December 18, 2018, 04:32:07 PM »
Slight leak at seal. It's hydraulic oil, assume from brakes.
If anyone has any input on this repair, I'd be grateful.
The Repair manual on the NAF bogie that came with machine is not very helpful.
Offline snowstorm
Re: Tandem axle bearing Valmet 646
« Reply #1 on: December 19, 2018, 04:01:49 AM »
is it at the seal or is it one of the steel brake lines rusted? there is a cast cover. a 6 or 8 " small steel line there that can rust through
Offline leeroyjd
« Reply #2 on: December 19, 2018, 05:03:15 AM »
Snowstorm I've had to replace those in the past. I'll double check, thanks!
Offline leeroyjd
« Reply #3 on: December 20, 2018, 06:34:52 AM »
@snowstorm are you talking about one of the covers on the bogie to get at the chain? Or the one on the axle that exposes that short steel line?
Wasn't at machine yesterday but will be double checking it today.
Offline snowstorm
« Reply #4 on: December 20, 2018, 06:41:01 AM »
short steel line with copper crush washers. its a good place to start
Offline leeroyjd
« Reply #5 on: December 20, 2018, 06:45:46 AM »
Ok Will check them. Thank you.
Offline leeroyjd
« Reply #6 on: December 20, 2018, 05:24:18 PM »
Unfortunately it's not that line.
Just to be clear it's leaking where the bogie pivots.
Offline leeroyjd
« Reply #7 on: December 21, 2018, 03:21:31 PM »
Offline leeroyjd
« Reply #8 on: April 14, 2019, 11:06:22 PM »
This leak stopped for the winter and oil levels were good.
It got bad while working today, and it seems like the brakes were engaged heating up the transmission temp.
Offline snowstorm
« Reply #9 on: April 16, 2019, 06:18:10 AM »
200 to 250 is normal trans temp. as far as brakes dragging that would have to be the working brake. released by the trans switch when its put in gear or something is amiss or a drift in the rear. pull the plug in the diff see what the oil looks like
Dual tandem axle vs triple axle singles
Started by mart on General Board
Last post February 24, 2016, 11:21:39 PM
by mart
single versus tandem axle for log/lumber hauling
Started by rmack on Forestry and Logging
Last post September 29, 2012, 06:51:47 PM
by thecfarm
Valmet 546 series II Forwarder Front Axle
Started by Wrenchman on Forestry and Logging
Last post December 11, 2018, 09:11:05 PM
by Wrenchman
Need Rear Axle 540 A Have Axle Assembly 440 C And 540D
Started by lonewolf on Wanted
Last post March 17, 2009, 10:40:15 PM
by lonewolf
