Author Topic: Considering port work on Stihl 362  (Read 2802 times)
Offline HolmenTree
Re: Considering port work on Stihl 362
« Reply #40 on: January 11, 2019, 09:32:54 AM »
My brother Dennis here ran a 7 pin on his Mac 101, he was getting times in the low 4 second range in 3 cuts with cold start included.
His saw has a 34mm carb and the pipe has a inverted stinger.
Look at them chips fly.
Offline Mad Professor
« Reply #41 on: January 11, 2019, 02:32:13 PM »
ya and its turning about 2500 rpms less in the cut than it should be once under load and listen to how the motor sounds . Its producing a ton of heat because your making it lug . You go ahead and run your 8 pin, I will stay with 7 pin, I have seen guys run 9 or 10 pin gears on saws , they thought it was faster but on video it was not
Did ya look at the video?  The saw has a tach on board and it's doing 11,500 in the cut.
So you want to spin a 034S at 14,000 rpm?   kaboom!!!
« Reply #42 on: January 11, 2019, 02:39:35 PM »
But how did he finish the cuts, after the chamber hit the cant? :o
« Reply #43 on: January 11, 2019, 03:04:08 PM »
Yea, sometimes ya need a 7-pin.
And those 034/036 don't have any torque either........
Offline HolmenTree
« Reply #44 on: January 11, 2019, 07:58:33 PM »
Seriously!! :D
Offline ehp
  • logger/chainsaw hack
« Reply #45 on: January 11, 2019, 10:26:32 PM »
its not turning 11500 in the cut when your leaning on it , Im talking the fastest way threw the block not making a video of a saw screaming doing nothing in the cut , Hell Man, over half the 0-81cc methanol /nitro stock appearing  saws are running a 8 pin so your going to tell me a saw of 60cc or less on pump gas is going to cut faster running a 8 pin and next time put the saw in some real wood, not that paper soft stuff , that's about like cutting white pine
Offline HolmenTree
« Reply #46 on: January 11, 2019, 11:12:07 PM »
Well said Ed.
Offline HolmenTree
« Reply #47 on: January 11, 2019, 11:27:04 PM »
Those Mac pipes are offset away from the power head to allow clearance from the log.
Here's two pictures from 1982 at The  Pas, Manitoba Canada during their winter festival.
In the  first pic is me with my 090 and my 2 brothers Dennis and Cliff in the back with their Mac 101's. All three of us were timber fallers at the time.
The guy with the red hat cutting with the 3rd Mac 101 is Jack Quinn a skiddder operator from the area. His cutting skills shows as he cut into a line on the log and was disqualified.
Last picture is brother Dennis winning it.
Offline ehp
« Reply #48 on: January 12, 2019, 09:53:59 AM »
who built the 090, I know Marcel sent a couple 090's out that way
Offline HolmenTree
« Reply #49 on: January 12, 2019, 01:46:03 PM »
Ed,  I built it myself. Madsens  built the pipe did the cylinder.
I fitted a 100cc kart reed valve manifold on it and put boost ports on the piston skirt. Then installed the 34mm Mikuni alky carb. This was my very first hotsaw build. Trouble was I was running a 11 pin sprocket on it and never won many races.
As last picture shows at the time our competition was a 400cc Husqvarna dirt bike saw built by Husky dealer Jim Hayes from White Fox, Saskatchewan.
Offline ehp
« Reply #50 on: January 17, 2019, 06:40:32 PM »
ya that pipe could use a lot of help on the 090, first real racesaw I ever built was a 090 , the faster I made it the more money it cost in parts LOL, got to the point I think a top fuel dragster was more dependable . first real problem is the crank with the flywheel sitting out so far away from the crank bearings and case is sure a weak link, it would break a crank as fast as it came out of the wood , took new crank and machined it to take a 064 flywheel in close to case and bearing , put new 064 coil in saw. crank breaking was fixed so switch to methanol with 20% nitro . Got saw to handle that but then the clutch would not handle the power and once I got that fixed I could not get clutch to stop slipping on the crank . Sure was a learning curve but helped me figure out how to solve problems . It was pretty fast but just never knew when trouble would show up so parked it and went with 3120
Offline HolmenTree
« Reply #51 on: January 17, 2019, 10:53:14 PM »
Madsens admitted the pipe was built for a Jonsereds 111 so didn't charge me for it. Still worked ok for size of wood I was running it in.
I had more plans for the 090 like a cut off head and epoxied transfer covers.
I did run it without the flywheel fan plate and got rid of the clutch. Made it direct drive with a 11 T spur sprocket and machined hub screwed onto the crank. Saved quite a but of weight and better spoolup off a cold start into the wood.
My next project was my last with the Yamaha YZ bike engine. Had alot of fun building and running  it over the last 30 plus years. Still a tough little little engine.
Offline ehp
« Reply #52 on: January 18, 2019, 06:23:00 AM »
i was running a 13 tooth at the end at a rpm the 090 was never meant to see LOL
Offline HolmenTree
« Reply #53 on: January 18, 2019, 10:47:28 AM »
Ed did you ever see anyone put a full circle crank in a 090?
It seemed everyone in the upper level of competition back in the 1980's was running a stock appearing saw with those crankshafts.
Offline ehp
« Reply #54 on: January 18, 2019, 05:20:21 PM »
ran I seen lots of full circle cranks , not really a fan of them . They tighten the crankcase up but you end up not being able to move much air inside engine compared to full race porting with a stroked crank . But the full circle crank sure makes building a carb a lot easier to run on methanol/nitro  , mainly cause it doesnot move as much air so no need for lots of fuel , The limiting factor is the amount of fuel a carb can move and how much torque/power can stuff like the crank take before it breaks , On gas you donot have this problem but on methanol/nitro you do have this problem
Offline ehp
« Reply #55 on: January 25, 2019, 05:13:38 PM »
On crankcase volume , there is a lot of things that go into this area and a lot more than a lot of people think goes into this , crankcase volume is very important on how much power a motor can produce . A stroked 3120 that is 60 mm bore by 46mm stroke has a ratio on 1.47 to 1 , the perfect ratio is 1.20 to 1 but to have that you would need to build a new crankcase with larger volume . Now on gas you could supply enough fuel to feed the motor at that ratio but on methanol/nitro that would most likely never be done , If motor was ported and piped to any kind of a race saw you just could not get enough fuel to it with a single carb which rules state we must use . The difference in hp is about double using a 1.20 ratio crankcase over the 1.47 . Main reason for double hp is cause the 1.20 crankcase  can move double the air volume and to make power you got to move air . You cannot compare a chainsaw engine to say a snowmobile engine. Most chainsaw motors are built with the bore/stroke ratio being totally backwards to a snowmobile engine so if you do the crankcase volume ratio on a snowmobile engine its a lot closer to the 1.20 ratio .
Port 576xp or buy and port 562xp
Started by woodchipper95 on Chainsaws
Last post January 26, 2016, 02:05:26 PM
by SawTroll
To port or Not to port a Husqvarna 365
Started by Addy89 on Chainsaws
Last post May 13, 2019, 01:58:32 PM
by Addy89
Stihl 044 no start after heavy work
Started by bertram31 on Chainsaws
Last post September 12, 2012, 11:08:10 PM
by bertram31
Stihl 017 issue - dies after a little work
Started by Coach on Chainsaws
Last post December 03, 2013, 11:24:05 PM
by joe_indi
