Author Topic: pecan in kiln  (Read 672 times)
Offline rjwoelk
    • countrysidefirewood
Re: pecan in kiln
« Reply #20 on: February 11, 2019, 04:56:30 PM »
I like the idea of a little access door to re-set the little red button :).  Good one, RJ.
Should be able to install some piano hinges and maybe a magnite to keep it closed.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: pecan in kiln
« Reply #21 on: February 11, 2019, 08:25:18 PM »
The best thing is to not run the temp up too high and trip it in the first place ;D
Offline xlogger
Re: pecan in kiln
« Reply #22 on: February 12, 2019, 04:40:03 AM »
The best thing is to not run the temp up too high and trip it in the first place ;D.
True, I've been lucky so far and not had to do it yet!
Talked to Stan yesterday and I'm going to run temp up to 145-150 for a couple days and then cool it down and cut compressor back on and see what happens.
Offline GeneWengert-WoodDoc
Re: pecan in kiln
« Reply #23 on: February 12, 2019, 08:26:06 AM »
If you do get temporary condensation on a meter whensed inside the kiln, you will see that the meter will read 12% MC or similar value right AFTER you leave the kiln with the needles not stuck into a piece of wood. At he end  drying, the dew point in the kiln is low enough that the risk of condensation is small.  It is at high moistures when this is an issue.
This condensation is also why some people report that drying slows or stops during drying...their MC reading is the issue.
The kiln samples are removed from the kiln, and not entire pieces of wood.
Pre-build solar kiln questions(Photos of kiln building progress)
Started by caveman on Drying and Processing
Last post April 17, 2016, 06:35:35 PM
by caveman
converting a bulk tobacco kiln into a lumber kiln
Started by Bryce on Drying and Processing
Last post February 18, 2010, 11:09:27 PM
by scsmith42
All the experienced kiln driers. Solar kiln or power?
Started by woodjunky on Drying and Processing
Last post December 13, 2014, 09:52:31 PM
by GeneWengert-WoodDoc
Kiln cart and shipping container kiln.
Started by Mike_M on Drying and Processing
Last post June 26, 2007, 08:57:21 PM
by Furby
