Author Topic: Woodmizer LT 40 Lubricant Help  (Read 1887 times)
Offline ehewitt05
  • Nose to the Grindstone.
« on: February 27, 2019, 03:21:01 PM »
What do you guys use for a lubricant on your blade while sawing?
We've always used Fresh Water but are having issues keeping the line thawed this time of the year. I always disconnect the tank (take it in), blow the line out and disconnect it so that it's hanging to try to get any depressions out,  but still come back to frozen lines. We're using a .045 x 1.5" blade with 7 degree hook sawin a lot of pine right now that for the most part is frozen.
Thought about using windshield wiper fluid. Obviously don't want to use something that is going to cause us more problems down the road (corrosion, bearing wear, etc.) but considering our Mill is no longer in a heated area its been a consistent battle. Also thought about rigging up heat tape on the line but thought the motor would keep a lot of this line cleared.
I'm in Western Pennsylvania too, it's not like we're in a brutally cold climate compared to a lot of guys on here.
Frustrated.
Any suggestions would be greatly appreciated
Offline Chuck White
  • Sawing Mobile since 2005
Re: Woodmizer LT 40 Lubricant Help
« Reply #1 on: February 27, 2019, 04:18:25 PM »
Welcome to the Forestry Forum, ehewitt05!
Lots of people use windshield washer during cold weather.  I don't saw once it gets cold, but I use water, dish soap & a cup of Pinesol (or the generic).
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Southside
« Reply #2 on: February 27, 2019, 05:29:19 PM »
I have gone to using RV anti freeze mixed in with water, it started as a way to use up some I had left over from a PPB application and I noticed that my pitch issues were greatly reduced in addition to not having frozen lines to deal with which is a real problem on my 70 with the lube mizer.
Windshield washer fluid has no lube or cleaning properties in my experience. But the RV stuff as an added bonus is non toxic too.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #3 on: February 27, 2019, 06:03:27 PM »
Ive used  Autozone windshield washer fluid in the past and flushed the lines with regular antifreeze when shutting down for a cold night.  I will try the stuff Southside uses when the opportunity presents.  Always looking for better.
HobbyHardwoodAlabama.com
Offline John S
« Reply #4 on: February 27, 2019, 06:43:56 PM »
Windshield washer solution, pinesol and Dawn.  Call WM in PA for more info.
2018 LT40HDG38 Wide
Offline Old Greenhorn
« Reply #5 on: February 27, 2019, 07:06:43 PM »
This is why I love the forums I have read this discussion several times before in other threads but never heard that little tid-bit that southside just put out. I had used the RV stuff in a pinch, but switched back to washer fluid, its cheaper. Now I will have to look at it anew, I still have some down in the mill shed. Learning stuff all the time here.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline Southside
« Reply #6 on: February 27, 2019, 08:18:06 PM »
Tractor supply sells a cheaper version and I picked up a couple gallons the other day to try it. Slightly different formula than the Lowes stuff, but so far the results are similar.  To date I have only used the TSC stuff on hardwood but will be getting to some pine in a few days so that will be a better test to see if it cuts the mustard - or in this case the pitch.
Offline richhiway
  • Rich
« Reply #7 on: February 27, 2019, 09:50:36 PM »
I have been using plain blue washer fluid all winter cutting pine. seems to work fine.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline WLC
« Reply #8 on: February 27, 2019, 10:42:30 PM »
I use water with with a dab of dawn and RV antifreeze mixed together.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
« Reply #9 on: February 27, 2019, 11:19:41 PM »
Windshield washer fluid and pinesol
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline ehewitt05
« Reply #10 on: February 28, 2019, 07:32:14 AM »
Thank you guys for the awesome feedback. I'll  give the Water/RV Antifreeze with some Pinesol a shot.
Offline Woodpecker52
« Reply #11 on: March 02, 2019, 09:48:00 PM »
Water, blue dawn, pinesol, and in winter mix in alittle windshield washing fluid.  I also added a alternative diesel lube system, use it from time to time to silence things a bit and really clean the blade.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline PA_Walnut
« Reply #12 on: March 03, 2019, 05:57:44 AM »
I use Cotton Picker Spindle lube all year and throw some -30 windshield washer in with it over the winter.
If it's gonna get super-cold (like 10 or below) I run straight washer fluid or Boost Juice methanol. (which is similar to washer fluid, but has more meth...-30 washer has about 39% methanol and Juice has 50%).
A side benefit is that you can inject it into the air intake stream of your forced induction engines and get even more joy!  ;D
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline slider
  • sawyer,trucker,tree service
« Reply #13 on: March 03, 2019, 08:29:49 AM »
The only thing i have found that works better than cotton spindle cleaner in pine is diesel. I saw mostly pine and have tried all of the above. If you use diesel set your lube on a lower setting to keep from throwing the band.
Diesel is messy so when i am through sawing each day i blow the mill with a strong back pack blower.
al glenn
Offline Mountain_d
« Reply #14 on: March 03, 2019, 07:35:19 PM »
JDo you use pure diesel or do you mix it with water? Not sure how it would mix?
Mountain
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Offline PA_Walnut
« Reply #15 on: March 05, 2019, 07:24:56 AM »
JDo you use pure diesel or do you mix it with water? Not sure how it would mix? Mountain
Petroleum and water do not mix. Think of the phrase, "Mixes like oil and water...".
Although I have never run diesel for lube, I'd imagine that you could thin it with kerosene or paint thinner. Anyone?
Northland 800 Kiln
« Reply #16 on: March 05, 2019, 08:36:12 AM »
I use the cotton picker spindle cleaner, I also occasionally spike it with diesel, but only under certain conditions.  When I add diesel to the spindle oil, the detergents in the mix will emulsify the diesel, and as long as Im sawing and shaking the water bottle with the head travel, it will stay in suspension although it wont really mix. However, when I stop for the day, the diesel will be separated the next morning.
I much prefer oils for blade lube and cleaner than water based mixes, but everybody should do what works for them.  Experimentation is key.
Offline ehewitt05
« Reply #17 on: April 09, 2019, 07:58:42 AM »
I've heard of other folks using diesel and really liking it. I thought that would be hard on the tank as well as the plastic drip line. Thoughts? I wouldn't mind trying it out, just unsure of how it would effect the plastic. I suppose it wouldn't be very different than a fuel can but that little line in the sun with fuel in it made me second guess this idea....
What do you guys think? We just got a load of white pine and two loads of eastern hemlock so now would be the time to give it a whirl...
Offline naturaledge1
    • Repose Fire Logs LLC
« Reply #18 on: April 09, 2019, 09:12:26 AM »
I have read in an engineers forum that windshield washer may cause dementia and the way it is atomized when using on the blade I stopped using it , it says on the label can not be made nonpoisonous. Warm weather water pine sol and soap , I use a spray bottle with WD to clean the blade fast . I have been running a 1989 LT40HD since 1991 headed to the three million mark. Starting to rebuild a burned 2005 LT40HD . Brian
« Reply #19 on: April 09, 2019, 03:52:08 PM »
Easy install on diesel fuel system.
UHMW Lubricant, Acme Thread Lubricant
Started by Trent on Sawmills and Milling
Last post December 03, 2006, 09:59:58 PM
by Kcwoodbutcher
Lubricant
Started by Bruser on Sawmills and Milling
Last post May 11, 2016, 05:02:53 PM
by Ox
Blade Lubricant
Started by running elk on Sawmills and Milling
Last post April 05, 2017, 09:41:02 AM
by york
Blade lubricant
Started by just_sawing on Sawmills and Milling
Last post January 21, 2011, 10:06:37 AM
by Bibbyman
