Author Topic: Woodmizer LT 40 Lubricant Help  (Read 1840 times)
Offline ehewitt05
  • Nose to the Grindstone.
Re: Woodmizer LT 40 Lubricant Help
« Reply #20 on: April 17, 2019, 03:06:29 PM »
I feel dumb asking this but what mix ratio do you guys use for pinesol/dawn with water? I would've thought just wing it dump a little in but wondering if I went too light with it
Thanks everyone
Offline gdaddy01
« Reply #21 on: April 17, 2019, 09:09:27 PM »
I have got to ask , we have been dealing with cleanup from hurricane Michael , reading tips on killing mold and mildew by putting peroxide into water and spraying it on . so now I am wondering if we could put peroxide into our blade cleaning water to help with sawed boards to help them with not mildewing . what do yall think , I already know I am a little crazy .
Offline barbender
« Reply #22 on: April 17, 2019, 09:39:22 PM »
I have intentions of putting a Cook's style felt wiper system on my mill. I hate using the water drip lube system unless I am sawing dry wood like cedar or green ash that needs the sawdust knocked down, just because of the mess of wet sawdust that ends up all over. With the felt pads, there is no free dripping diesel, it's just constantly wiping a very thin film of fuel on the blade that keeps anything from sticking to it. I'm speculating, but I think a half cup of diesel would make a whole day of sawing. In another lifetime, I worked on an asphalt paving crew and we had these strap on "shoes" that had a flat felt sole. You would soak these with diesel (very similar the felt track wiper on an LT40) and you could walk on the asphalt for hours without it sticking to the shoes. You don't have to have diesel pouring off of your track wiper to keep pitch from building up on your top rail either, just that film. In my experience, things get bumpy quick when that wiper gets dry as the sawdust and pitch build up on the top rail immediately. Actually spraying the diesel out of the Lube-mizer or drip tank is way too much diesel, IMO. I know with that SYP, a guys gotta do what a guys gotta do but I think it could be accomplished with a lot less. If anyone is interested, look at Cook's wiper system on their website (it's available as a retrofit). If I remember right, it looks like it would hold less than a cup of fuel anyhow.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #23 on: April 18, 2019, 11:01:00 PM »
The more you put in the better it will work. As an analogy, if you have grease on your hands, and use too little soap, just turning up the water still wonít clean them.  It takes more soap.  So keep adding more until it works.
Iíve used Diesel with my Lubemizer no problem.  I had it set to lowest, so it only sprayed the band once maybe twice per cut.  Worked great.
HobbyHardwoodAlabama.com
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #24 on: April 19, 2019, 07:20:42 AM »
For sawing Hemlock I dont use anything.
Minuscule build up of any kind
EWP and Ash, Water and Pinesol.
Actually lube is a bit of a misnomer.
You are cleaning the blade and cooling a very little bit as the green sawdust and air mix is a good cooler.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #25 on: April 20, 2019, 06:47:13 PM »
Friday was sawing ash mixed  with red oak. Lube didnít do too good on the ash.But the Oak cleaned the band right up.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member.  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker),  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
UHMW Lubricant, Acme Thread Lubricant
Started by Trent on Sawmills and Milling
Last post December 03, 2006, 09:59:58 PM
by Kcwoodbutcher
Lubricant
Started by Bruser on Sawmills and Milling
Last post May 11, 2016, 05:02:53 PM
by Ox
Blade lubricant
Started by just_sawing on Sawmills and Milling
Last post January 21, 2011, 10:06:37 AM
by Bibbyman
Blade lubricant
Started by timberfaller390 on Sawmills and Milling
Last post November 05, 2008, 09:10:31 AM
by slider
