Author Topic: Timber Jack/Eaton winch question  (Read 332 times)
Offline Hans1
« on: March 08, 2019, 08:43:01 PM »
The winch on the 225 timberjack I am running has broken the small steel strap that connects the right side collar to the frame of the skidder. This strap appears to keep this collar from rotating there is a hydraulic line is 180 degrees from the recess that this strap fits into. When this strap broke it broke the swivel fitting on the hydraulic line. Hoping we are to the bottom of this problem and it isnít a sign of problems deeper in the winch. Any thoughts or ideas would be great.
Offline dnash
Re: Timber Jack/Eaton winch question
« Reply #1 on: March 08, 2019, 09:03:30 PM »
Your thrust bearing is shot. It sits just behind the collar that the strap holds.
JD 440C
JD 640D
Timberjack 205HR
JD CT322 skidsteer
Offline Hans1
« Reply #2 on: March 08, 2019, 11:51:03 PM »
Thanks for the info I figured it had to be something else I would assume take the winch off and go from there. Also thanks again what a great resource.
Offline Hans1
« Reply #3 on: April 13, 2019, 09:56:59 PM »
Thanks for the help it was the thrust bearing. We took the winch of and took it to a small Amish shop about 300 good to go
Old Eaton Timber Jack front hub replacement parts
Started by pro_vagabond on Forestry and Logging
Last post December 17, 2014, 07:16:26 AM
by timberjackrob
Timberjack 230D Eaton winch question
Started by Goodndusty on Forestry and Logging
Last post June 12, 2014, 09:15:58 AM
by Goodndusty
timber jack won't steer when winch freespools
Started by Caseybow123 on Forestry and Logging
Last post September 24, 2017, 05:33:28 PM
by Coltbodi
eaton winch
Started by poorfarm on For Sale
Last post May 23, 2012, 03:49:28 PM
by poorfarm
