Author Topic: those Woodmizers are handy. table leg videos  (Read 1533 times)
Offline richhiway
  • Rich
« on: March 21, 2019, 06:21:09 AM »
Turn some table legs on the table saw with a jig.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline richhiway
  • Rich
Re: those Woodmizers are handy. table leg videos
« Reply #1 on: March 21, 2019, 06:22:25 AM »
Cut those legs square on the LT 40.
Woodmizer LT 40
Stihl Chainsaws
Offline ellmoe
« Reply #2 on: March 21, 2019, 06:57:06 AM »
Very clever "lathe". smiley_applause
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #3 on: March 21, 2019, 08:03:07 AM »
That is super sweet lathe setup.
Offline marcnaz
« Reply #4 on: March 21, 2019, 08:44:04 AM »
That's neat. Ya learn something new every day! Thanks for the post.
USAF Retired
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #5 on: March 21, 2019, 09:05:04 AM »
   Neat jig set up with the table saw. May be faster and sure looks easier than using my tenon cutter. Results look about the same
 I put mine in a vice and use a wrist breaking half inch drill with a tenon cutter.
 Ash legs for stock
    The table saw looks like a lot less wear and tear - my only concern would be the height adjustment on the blade to get the exact diameter on the peg/tenon. Once set they will certainly all be the same.
Rich's leg trimming looks just like my process which does give the same angle and height on each leg. Would work just as well for a 12' bench as a 3' one.
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #6 on: March 21, 2019, 09:35:49 AM »
Nice, thanks for the videos !
Offline charles mann
« Reply #7 on: March 21, 2019, 02:52:47 PM »
Aint that a cat’s meow!!
Temple, Tx
Offline WLC
« Reply #8 on: March 21, 2019, 02:58:11 PM »
Very cool!  Thanks for sharing that tablesaw lathe.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Offline Old Greenhorn
« Reply #9 on: March 21, 2019, 04:30:44 PM »
That is slicker than deer guts on a doorknob! I don't have a table saw, but I do have a radial arm saw. I am wondering how thick that blade is you have on your saw? What size is the threaded rod you run through the middle of the leg, and how deep do you go with it?
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline jaygtree
« Reply #10 on: March 21, 2019, 06:08:11 PM »
that's a lot easier way of cutting your bench legs the same length than how i've been doing it. thanks for the tip. also nice home made cylinder mill.  jg
i thought i was wrong once but i wasn't.   atv, log arch, chainsaw and ez boardwalk jr.
« Reply #11 on: March 21, 2019, 06:55:32 PM »
   Here is a thread I posted the whole process I use. The best pictures start around reply 37. The sawmill works great not only to get the leg length right but it also cuts them all to the correct angle.
Still making benches in General Woodworking
    One thing I noticed here was the addition of the board on the bottom. I like that if you wanted to use a 4/4 board or slab instead of 8/4 or larger. I used to make them with 4" thick slabs and bury the whole tenon in the slab but I find 8/4 is much lighter and still plenty strong. If you wanted to make a 12-16 ft bench you could just add extra legs along the way and still cut them all the same with one pass on mill.
Offline ljohnsaw
« Reply #12 on: March 21, 2019, 07:29:52 PM »
Way cool!
I'm thinking that he is just using a lag screw into a pre-drilled hole.  It both holds the piece of stock and provides the drill with a place to spin it.  Very nice.
Edit: I went back and looked again - he is using a regular bolt.  For the top end, I would use a sharpened bolt (like a center on a lathe) so there would be a minimal hole that could be cut off if the legs were through-mortised into the bench top.
As far as blade height, if you make the hole in the jig something like 3" off the table, then you would just set the blade to 2½" for a 1" tenon, 2¼" for a 1½" tenon and 2" for a 2" tenon.
Offline John S
« Reply #13 on: March 21, 2019, 07:41:18 PM »
Wish I was as creative as these two great ideas. I am good at learning from others, though.  Thanks for posting.
2018 LT40HDG38 Wide
Offline richhiway
  • Rich
« Reply #14 on: March 21, 2019, 10:49:47 PM »
It is 3/8 threaded rod. I reversed one of those tap in  T nuts and bent the tab the other way to drive it.
I used two of these bearings on each end and double nutted the rod in. I filed the threads down on the non driven side.
Once you have the blade set to the right height,you lock it and all the legs are the same diameter.
It is just a plain contractors blade. Maybe 3/32 kerf.
Woodmizer LT 40
Stihl Chainsaws
Offline richhiway
  • Rich
Woodmizer LT 40
Stihl Chainsaws
Offline Percy
  • Resident trouble maker
« Reply #16 on: March 22, 2019, 10:36:41 AM »
Patsy Cline 👍👍
Offline richhiway
  • Rich
« Reply #17 on: April 19, 2019, 05:10:54 PM »
here is a photo of the finished table.
Woodmizer LT 40
Stihl Chainsaws
Offline richhiway
  • Rich
« Reply #18 on: April 19, 2019, 05:12:07 PM »
and another. Happy Milling!
Woodmizer LT 40
Stihl Chainsaws
« Reply #19 on: April 19, 2019, 06:08:58 PM »
  Pretty cool. How thick are those souped up table top cookies?
woodmizers in for it now !!!!
Started by loggah on Sawmills and Milling
Last post August 05, 2018, 08:46:12 PM
by Kllisk
rebuilding woodmizers
Started by steveo_1 on Sawmills and Milling
Last post January 06, 2005, 09:26:27 AM
by KILROY
question
Feedback on Woodmizers
Started by Woodlotguy on Sawmills and Milling
Last post May 13, 2002, 12:44:13 PM
by Tom
WPF & Woodmizers in Ukiah, CA
Started by theorm on Shows, Events and Places to meet
Last post March 12, 2008, 01:09:21 AM
by theorm
