Author Topic: solar kiln temp  (Read 446 times)
Offline ccb
solar kiln temp
« on: March 21, 2019, 03:48:55 PM »
Can a solar kiln get too hot? Outside temp currently 47 F. Temp in top of building/collector is currently 154 F where the fan isn't running, and is 120 F where the fan is running and blowing air down below to the wood. The solar collector is 36 ft long. This newly operational. Can't imagine what the temp will be in the heat of summer in Wisconsin. Thoughts?
Offline henry-sawer
Re: solar kiln temp
« Reply #1 on: March 22, 2019, 02:40:52 PM »
Hi, mine did that too, all that will change when you put a bunk of wood in there.
Offline GeneWengert-WoodDoc
Re: solar kiln temp
« Reply #2 on: March 23, 2019, 07:05:28 AM »
The heat at the top can easily reach 200 F and can melt or damage wires, fans, plastic, wood components, roof covering materials, etc. when the air is stagnant.  You need vents near the top that are open when the unit is not in use, or run the fans or put a cover over the roof.
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: solar kiln temp
« Reply #3 on: March 23, 2019, 07:46:07 AM »
I melted the roof on mine, when we had a couple day power outage and I forgot to open the doors.
HobbyHardwoodAlabama.com
Monitoring Temp & RH in a Solar Kiln
Started by JackLeg on Drying and Processing
Last post May 16, 2008, 08:31:31 PM
by JackLeg
Solar Kiln Temp Probe Locations
Started by GF on Drying and Processing
Last post September 14, 2004, 10:12:21 PM
by Den Socling
Mental Exercise! Hybrid kiln design (solar drying concept w/o solar heat)
Started by scsmith42 on Drying and Processing
Last post March 31, 2016, 10:51:46 PM
by GeneWengert-WoodDoc
Kiln Temp
Started by Paul_H on Sawmills and Milling
Last post November 23, 2003, 07:03:38 AM
by Paul_H
