Author Topic: Deposit lt35 or wait a month lt40 wide  (Read 3676 times)
Offline Bruno of NH
« on: April 02, 2019, 11:42:31 AM »
Just put a deposit on a new mill .
Lt40 35hd25 with debarker
That's if the financing go through .
I might have it before the project.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Deposit
« Reply #1 on: April 02, 2019, 01:35:32 PM »
Wow. Thatís great news.  Congratulations.
HobbyHardwoodAlabama.com
Offline Bruno of NH
Re: Deposit
« Reply #2 on: April 02, 2019, 02:13:19 PM »
Thanks YH
I have a family member investing in helping me out till I get my health right.
Offline Southside
Re: Deposit
« Reply #3 on: April 02, 2019, 03:38:22 PM »
Awesome choice Bruno!!!  Whoo Hoo!!!
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Deposit
« Reply #4 on: April 02, 2019, 04:14:35 PM »
you won't be sorry you got hydraulics
Jim Rogers
Offline Bruno of NH
Re: Deposit
« Reply #5 on: April 02, 2019, 04:32:25 PM »
I placed my deposit with Marty Parson at the Pa branch
Offline tacks Y
Re: Deposit
« Reply #6 on: April 02, 2019, 05:21:17 PM »
Sweet, You guys need to form a club. The NEW WM Club.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Deposit
« Reply #7 on: April 02, 2019, 08:03:48 PM »
Congratulations my friend.  This is going to be a vast improvement and should be a big help toward taking some of the load off of your knees.  thumbs-up
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
Re: Deposit
« Reply #8 on: April 02, 2019, 08:09:24 PM »
Awesome Bruno. Happy for you.
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Deposit
« Reply #9 on: April 02, 2019, 09:10:17 PM »
smiley_thumbsup
A&P saw Mill LLC.
License NH softwood grader.
Offline Oliver05262
Re: Deposit
« Reply #10 on: April 02, 2019, 10:05:05 PM »
  Congratulations on the new mill, Bruno. 8) Even if it's not there for the project weekend, I will come over to see it as soon as it's there. Maybe even help you run it for a day. :)
Oliver
"You can't do wrong by doing good"
It's OK to cry.
Offline 69bronco
Re: Deposit
« Reply #11 on: April 03, 2019, 06:31:41 AM »
 8)
Offline Bruno of NH
Re: Deposit
« Reply #12 on: April 03, 2019, 07:42:21 AM »
I have never used set works
How does it work ?
I might need a class
Offline Southside
Re: Deposit
« Reply #13 on: April 03, 2019, 09:13:54 AM »
Did you get Simple Set or Accuset 2?
Offline Bruno of NH
Re: Deposit
« Reply #14 on: April 03, 2019, 09:38:04 AM »
I think it's simple set
I have only had simpleton set  :D
Offline barbender
Re: Deposit
« Reply #15 on: April 03, 2019, 11:32:01 AM »
Simple Set is like it says, pretty simple😊 If it works like my old "Setworks" on my 97 Super (which I'm pretty sure it does) it measures down from the current saw setting. Mine has 4 presets. So say preset 1 is for 4/4. Your head is at 10", you hit preset 1, and then tap the lever to lower the head. The head will automatically drop down to 8 7/8" (because you preprogrammed your kerf😊). Saw through, raise the head to clear the cant and gig back. Now you just tap down again. It will automatically drop from 8 7/8" down another 1 1/8" to 6 3/4". It's handy, and saved me time in two ways. First, when you're making opening cuts, not having to do any math in your head to drop down and get a certain board thickness by simply pressing a button. Also, on my Super the head up/down is really fast. Too fast when you are trying to hit a target manually! With the setworks, while you're gigging back, as soon as you clear the cant you just tap the down control and the head drops to the next cut before you've even got the head stopped and ready to go forward. Whereas, doing it manually I land on the target about 1 time out of 10🙄 The shortcoming of the Setworks program was it doesn't measure relative to the bed, only to the head position where it was activated. So when sawing a cant to the bed, if you don't start at the right thickness, you end up with a thick or thin board on the bottom. I hope my complicated description of Simple Set didn't ruin it for anyone😁
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Deposit
« Reply #16 on: April 03, 2019, 01:10:20 PM »
I may stand corrected but I do not believe that SimpleSet allows for kerf.  SetWorks does.
Offline Sixacresand
  • John and Nancy
Re: Deposit
« Reply #17 on: April 03, 2019, 01:29:28 PM »
Good for you, Bruno.  You will enjoy it.
Offline thecfarm
Re: Deposit
« Reply #18 on: April 03, 2019, 01:40:48 PM »
You will like it!!
Offline crowhill
Re: Deposit
« Reply #19 on: April 03, 2019, 01:45:59 PM »
Thatís pretty awesome Bruno!
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
LT35 vs Used LT40 ??? Help!!!
Started by Dad2FourWI on Sawmills and Milling
Last post November 21, 2013, 03:41:15 PM
by Finn1903
How much robust is the LT40 over the LT35
Started by Tree Dan on Sawmills and Milling
Last post April 21, 2019, 08:49:43 AM
by thecfarm
Wood Mizer Power feed LT35 and LT40 new design
Started by MartyParsons on Sawmills and Milling
Last post December 05, 2017, 12:11:12 AM
by MartyParsons
