Author Topic: Deposit lt35 or wait a month lt40 wide  (Read 3586 times)
Offline GAB
Re: Deposit
« Reply #20 on: April 03, 2019, 03:49:06 PM »
I may stand corrected but I do not believe that SimpleSet allows for kerf.  SetWorks does.
MM:
I think you are correct.  At least that is what Dave in NH told me at Bruno's sawing party last year.
Gerald
Offline trapper
Re: Deposit
« Reply #21 on: April 03, 2019, 04:07:43 PM »
Then can you program each width 1/8" more to get what you want?  Like 1&3/8 to get 5/4.
stihl ms241cm ms290  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline Bandmill Bandit
Re: Deposit
« Reply #22 on: April 03, 2019, 04:10:55 PM »
Simple set you hav to add an 1/8th to you measurement for Kerf.
6/4 equals 1 5/8" on the simple set system,
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Offline Bruno of NH
Re: Deposit
« Reply #23 on: April 03, 2019, 04:14:10 PM »
So how do you know what size cant to make?
thomas 8013 mill, Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline GAB
Re: Deposit
« Reply #24 on: April 03, 2019, 05:17:56 PM »
Keep a pad of paper, a pencil and a calculator handy.
I hope you are good at math.
You might want to make some cheat sheets and get them laminated for reference.
Gerald
Offline Bruno of NH
Re: Deposit
« Reply #25 on: April 03, 2019, 05:30:05 PM »
I got a good construction calculator  :D
Offline Southside
Re: Deposit
« Reply #26 on: April 03, 2019, 05:56:38 PM »
You will do fine with simple set, as said it does not automatically compute for the kerf so you set that into your programmed drop. It's easy, I am about the most computer illiterate person out there and it took me maybe 5 minutes to figure it out.  You can also use it in manual mode and it will have an inch and quarter scale for reference.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Deposit
« Reply #27 on: April 03, 2019, 08:58:01 PM »
With simple set, you have to add the kerf.  So, If I am sawing hardwood at 1 1/8" thickness rough, I have to program the simple set at 1 1/4" to get a 1 1/8" board.  1 1/8" board plus 1/8" kerf = 1 1/4".
There is a scale with 4/4, 5/4, 6/4, and 8/4 markings on it that you use to position the blade on the opening cut so that you get an even number of boards to the bed.
Re: Deposit
« Reply #28 on: April 03, 2019, 09:30:09 PM »
Bruno there are several methods as have been indicated above and I have tried a few of them HOWEVER, the most effective method I have found is to use the ruler for a target range finder.
If you cutting 4/4 x 6 then cut to your closest 4/4 mark on the ruler as your last side cut PRIOR to the first finish thickness cut. The dimension across will be 6 (+ the 1/8 for kerf, set 2 on your simple set screen to leave you a true 6" width) Your depth setting (set 1 the way I do it) for 4/4 will be 1 1/8.  That way don't need calculator or cheat sheet.
I use set 1 for depth and set 2 for the width setting. Using the ruler is about the same result as accuset cause the ruler measures from the bunk rails and never changes. Using the ruler as the target to get simple set started to is very effective and quick.
Re: Deposit
« Reply #29 on: April 03, 2019, 09:38:53 PM »
When sawing hardwood, don't forget to flip your ruler to the hard wood side and make sure it is zeroed properly.
Offline Bruno of NH
Re: Deposit
« Reply #30 on: April 04, 2019, 04:42:54 PM »
Have a sale pending on the Thomas
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Deposit
« Reply #31 on: April 04, 2019, 06:32:32 PM »
Great
Offline Bruno of NH
Re: Deposit
« Reply #32 on: April 05, 2019, 12:00:38 PM »
The sale on the Thomas fell through
Offline Bruno of NH
Re: Deposit
« Reply #33 on: April 05, 2019, 12:33:23 PM »
Might change my mind
Just asked Marty to price out a lt40 wide head 38 hp gas
Online WV Sawmiller
    • Green's Sawmill Services
Re: Deposit lt35 or wait a month lt40 wide
« Reply #34 on: April 06, 2019, 10:23:32 AM »
Bruno,
   Congrats to you. I use my simpleset religiously and made up a cheat sheet of the common sizes I saw. It saves me an additional cut or a thick or thin board on almost every cant. I start using my cheat sheet when I flip to the final face on the log/cant.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #35 on: April 06, 2019, 12:00:27 PM »
I think an LT40 Wide would be a better choice if you have a slab market, but it's easy to spend your money.  :)
Offline Bruno of NH
« Reply #36 on: April 06, 2019, 12:46:31 PM »
Dave
I think it's a no brainer for me.
I'm also trying to bring in black locusts and more spruce
Online thecfarm
« Reply #37 on: April 06, 2019, 12:53:39 PM »
I have never sawed on a WM wide head. But I suppose you can saw small stuff on it just fine. Than when you want to saw the wide stuff you can do that too. On a regular WM mill,the wide stuff can not be done.
Offline Bruno of NH
« Reply #38 on: April 06, 2019, 01:12:58 PM »
Ray and Dave,
Can you guys make it to the Northern Project on May 4th?
It would be great to have you both.
Offline tawilson
« Reply #39 on: April 06, 2019, 01:26:27 PM »
Simpleset works fine for me but I don't really know what I might like better about the Accuset,  except I'm positive I would like the blade height readout.
2017 LT40HDG35 WIDE
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
LT35 vs Used LT40 ??? Help!!!
Started by Dad2FourWI on Sawmills and Milling
Last post November 21, 2013, 03:41:15 PM
by Finn1903
How much robust is the LT40 over the LT35
Started by Tree Dan on Sawmills and Milling
Last post April 21, 2019, 08:49:43 AM
by thecfarm
Wood Mizer Power feed LT35 and LT40 new design
Started by MartyParsons on Sawmills and Milling
Last post December 05, 2017, 12:11:12 AM
by MartyParsons
